wtb - porsche 5x205 pattern wheels
https://forums.aussieveedubbers.com/threads/88774/wtb-porsche-5x205-pattern-wheels
norbert ·
Anyone have or know where I can get a set of 5x205 standard porsche rims. I have a set of 15 x 5 mangels with 195/65 R14 tyres (almost new) which are to large for my KG.
Mangels are in reasonable condition and should polish up well.
If anyone is interested I am happy to swap and pay difference.
OldBoyOval ·
Try Smaller Tyres
165 on the back and 135 or 145 on the front, then you can go really low too!
oldtub356 ·
norbert, Can you have another look at your sizes - it is a bit confusing:
You say that you have 15 inch diameter Wheels but 14 inch diameter Tyres available
and,
5 inch Wide Mangle - I thought that Mangles came only in 4.5" and 5.5" wide.
FYI: Standard Porsche rims were:
4.5"x15" and 3.5"x16"
Also, where are you located?
Lance.
karmannghia60 ·
Standard 16” porsche were 3.25" not 3.5"
norbert ·
Hi Oldtub,
Will double check. Pretty sure the tyres are what I stated know its confusing. Your probably right about the mangle sizes, I was told 5" but more likely to be 5.5's.
Norbert
oldtub356 ·
Sorry Rafik, My 16" "standards" were alloy rims from a Spyder/early Carrera - factory, untouched from new - the rim material was much thicker than steel rims and they were 3.5" at the tyre rim - I haven't had steels. My mistake.
Lance.
crsedge ·
You can also get 14" Porsche Fuchs for your 14" tyres as well, not as readily available, but when they are will actually be cheaper generally than 15"
Craig
Calcool ·
I have a set of original 14inch Porsche Fuchs in Sydney.
Need paint and polish $1000
David
norbert ·
Finally checked the tyre sizing. Was feeling dumb the other day. So the mangles are 14" and I presume they are 5.5"wide as the tyres are 195/70 R14.
Know that I can change the tyres to fit, but too much stuffing around.
Colcal, the tyre pattern is 5 x 205 and already purchased a fairly expensive disk brake conversion ($1000) with that stud pattern. Don't really want to change, hence after porsche type wheels with that pattern.
Thanks anyway, anyone out there have a set?
Norbert😊
Judsons4eva ·
Gary at Wolfsburg Automtive near Geelong has them new for $300 a set delivered
norbert ·
Thanks Judson
