Driver side door sagging
https://forums.aussieveedubbers.com/threads/88814/driver-side-door-sagging
Blue65 ·
Hi. I'm having trouble closing my right hand (drivers) door.
Not sure how to fix it.
Just adjust it.
If you cant adjust it, check if the hinge pins are worn and recondition the hinges and go from there.
hellbugged ·
adjust the striker plate on the B piller
or as above
or worse the hinge broken off inside the door
cam070 ·
You could just get new hinges, they aren't that expensive. Joel did a DIY on how to replace them.
Blue65 ·
cam070 wrote:You could just get new hinges, they aren't that expensive. Joel did a DIY on how to replace them.
Do you have the link for Joel's DIY ?
And where can I buy new hinges? Good ones?
Is there a VW shop in Victoria which stocks the parts - I know that VW used to make Beetles in Clayton.
It's stickyed in the top of the tech mods forum
but here ya go 😉
http://forums.aussieveedubbers.com/viewtopic.php?tid=85049
I doubt you'll find anyone in aus selling new hinges but CIP in cali stock them, pretty cheap too.
