Hi guys
I would like to know what, if any, issues I might have in getting a Karmann ghia road-registered in NSW?
It is LHD from USA year is 1965, already imported by someone else.
make sure you get all the paperwork
grumble ·
vw54 wrote:make sure you get all the paperwork
x2
Need an Import approval and proof of ownership to start with.
surreyp ·
Yeah it will be imported with paperwork, I am more concerned with rego checks, like the check of the car to meet the Australian Design Rules.
Will it pass as-is or will it need work eg different seatbelts, tail lights, etc?
cwatts181 ·
Hi - I have a 72 Ghia imported from the US, now registered in NSW so left hand drive. If the car doesn't have the original import certificate you can ask Dept of Transport for an excerpt - they will not issue the original certificate to anyone but the original importer... but the excerpt is fine. With rego you need to get the blueslip from an authorised inspection station.... and as I understand it the specifications for inspection/registration correspond to the year of manufacture. My Ghia is not showroom condition, a bit rough but rego was no problem. I am in country NSW and just went thru a blueslip process for an old landcruiser that has been sitting in a shed for 3 years, mechanicals are all fine but electricals are suspect, but passed with no problem - I think country standards are more realistic than city standards for old cars.
Yogie ·
You will need the headlights changed to RHD versions as well as have the parking lights put in them instead of the blinkers. Seat belts will also be needed that comply with Australian standards. You MAY need to change over the tail lights to amber topped versions but not sure on that one. All you will need then is your roadworthy certificate and you should be OK.
Yogie
bajachris88 ·
Seatbelt adr's weren't made in 1965 though. Adr's didn't exist.
