Cv Joint bolts loosening
https://forums.aussieveedubbers.com/threads/88823/cv-joint-bolts-loosening
liam66 ·
Got a small prob with the bolts holding the CV joints in constantly working loose.
I've been lock tighting them and tightening as far as I dare- still coming undone.
The axles seem to be the right length ( I guess) as at rest i can moove them back and forth by about 5mm.
The bolts themselves are aftermarket ( not genuine VW) Is this the problem?
66brm ·
Do you have the little wavy washers under the heads of the bolts?
go and get some S/ Hands one and make sure u fit the wave washers
tighten the evenly as well
liam66 ·
Thanks guys, now i've got a project for tommorrow.
dangerous ·
You also MUST have the bridge plates under the serated washers.
