Aussieveedubbers · VW Circuit Racing
camber with accentric bush
https://forums.aussieveedubbers.com/threads/88831/camber-with-accentric-bush
cnfabo ·
how much camber can u get with the extra accentric bush without bending the top arm.....for a beetle...
mactaylor ·
i got 1.5 degrees max which is prob not gunna be enough.
cnfabo ·
cheers mac, looks like im bending the top arms then....
Aussie Dubbin ·
When i looked into it they all said bend them... i haven't put mine back together yet but, should be able to get 4* neg
It should give you 1.5- 2 deg more than your standard one..............so about 2.5 deg MAX.
cnfabo ·
will i need to run the clearenced ball joints or the stock ones will be fine.....being that the car is as low as any other hillclimb car....
