vwbugsrule wrote:I have got a 1961 beetle 1200cc and at the moment it has the original 28 PICT carby on it, but i dont think it is the best as the engine hesitates on acceleration. ( i have cleaned it out, its been tuned ect..) I want to get a new carby, which carby do i buy ?
As Phil has said, keep the 28PICT carburettor. It is as good a carburettor you're going to get for your engine.
I have a 1200 6V bug, and I wouldn't change any of the original equipment on it.
What distributor do you have? Is it the 009? If so, there is an inherent lag in these distributors as they are mechanical advance. Not vacuum advance like the original Bosch distributors.
Is the choke working? If not, it may be closing more than it should be, starving the engine of air it needs.
How is the float level in the carburettor? If it's too low, it may be shutting off the fuel too early (i.e. there could be a hole in the float).
How is the fuel pump? Is it pumping out enough fuel pressure?
Valve clearances .006" although some say .008"
Plugs at .026" to .028"
Points at .016"
Timing 10BTDC to 7.5BTDC
Hope this helps
