Face Book
https://forums.aussieveedubbers.com/threads/88914/face-book
donn 路
What the hell has happened to my face book, I use it a lot, (last night was the second time this year) and now my page is all in some foreign language, Russian I think, can someone here tell me how to change it back. Knew I should have stuck with the quil and ink well. 馃槵
65standard 路
You say it's happened before? How did you get it back before it happened again.
Are you able to login and get to the account tab? (4th tab on the right side of the page.
Once you're in settings, go to "Language" tab 5th on the right. Then go to the dop-down menu and select English-UK tab.
Hopefully this gets you back into the English language. Also, set your account and privacy security settings so that only friends can chat with you if you haven't already done so.
Hope this helps.
Ollie 路
Haven't you herd? Russian is the new English!
donn 路
Thanks 65, no, you read it wrong, I realy don't use face book often, just trying (and failing) to be smart, 2nd time I've used FB this year, first time for the language change. I'm off to try to rectify it.
Mr Clarke, your no help if Russian is the new English then I'm in the deep stuff and how do you spell herd, or is it heard? 馃お
Ollie 路
Hah - touche.
What 65 said was right though, try fiddle through the tabs to try and find the language settings.
Or hit up google translator and begin learning Russian!
