clutch guide sleeve conversion
https://forums.aussieveedubbers.com/threads/88959/clutch-guide-sleeve-conversion
ernie norley ·
Gday all. Has anyone out there used the sleeve conversion on the early type 3 box that inserts into front input shaft inplace of g/box seal to take the later clutch thrust bearing i have found 1 at machine7.com in UK but would like to get locally if possible thanks
Ernie
ernie norley ·
Gday all sharpbuilt have the sleeve thanks
Ernie
dangerous ·
Let us know how well it fits.
A lot less work than drilling and tapping 7mm threads!
ernie norley ·
Gday Dangerous I have A 180b motor with a modified beetle flywheel running a 228mm kombi clutch.In my baja. I ended up using an adaptor ring that clips onto p/plate to take up the gap. But will get 1 eventually for other box.
