New old 1641
https://forums.aussieveedubbers.com/threads/89137/new-old-1641
telf ·
Hi i thought id put it in this section as i thought some 1 might have the answer.
I've just picked up a second hand 1641 type 3 motor. It was rebuilt a few years ago. I was told it had a new cam put in a lightened fly wheel and a few other things oh and its a single port. It ran for about 10,000ks and then was taken out so it has been sitting for a while. Not sure whether or not to strip the top and the bottom or just the top. I have another motor with twin port heads and wondering if its worth swopping the heads and having twin carbies. Hope some 1 can give me some advice and i've not confused you.
Thanks Telf
Stanley ·
If you strip the top this may give you an idea what the bottom is like and then you may as well fit the TP heads. All depends what you're after.
telf ·
Thanks, sounds like a good starting point. The motor will be in a daily driver. At the moment the 1 that is in there is getting old an tired. I just wanted a mild up grade and this 1 was free!
thanks
DavoBuggy 1641 ·
Hey Telf, If you want to get the most out of that set up you should really spend the money on the heads and carbs. I built a 1641cc engine for my Manx Containing stock crank, engle 110 cam (mild), new 1641 piston barrel kit, racing lifters chromoly pushrods, then machined the heads to a 9:1 compression, 40mm stainless intake valves 35mm stainless exhaust valves, hardened seats (run 98 octane pump fuel) and twin cadrons with stock ignition except iridium plugs. This produced 70hp at the wheels. With heads like mine you could even run webbers for even better performance. Hope this helps.
Cheers Dave!
FROSTY ·
Hi Telf, if your going to pull it down soon give me a call I will come round and have a look. I have a new number 0421067754 give me a call.
Frosty.
telf ·
Hi Davo thanks for the advice.
Mr frost is gona have a look when ive pullet it down to see what ive got on my hands.
Cheers jason, i think next sat is th go ill give you a call in the week.
telf ·
Hi jason thanks for your help today really appreciated it. Got it all stripped down. Emptied the the oil out and it was 3quaters oil and a 1/4 water (bugger). I also looked at the con rods and they were covered in surface rust so not sure how bad that is? They felt ok on the crank so will have to see. Well cheers once again and hope you had a good day in the rain.
Oh for putting a clean engine together.
one day!
