engine swapping
https://forums.aussieveedubbers.com/threads/89222/engine-swapping
Stephen62 ·
Does anyone know if a 1970 beetle 1500 engine will fit straight into a 1962 beetle ?
I assume it will eventually, but will it need modification ?
Does 1200 engine tin fit on a 1500 ?
Are there any other hurdles to overcome ?
ragged ·
1. The motor will not go straight in.
2. It will fit with some mods.
3. Fan housing is the same but that's where it ends.
4. Are you running 6 or 12 volt?
as ^^ said
has a lot to do with flywheels, starter motors, gear boxes, 6volt V's 12 volt
hellbugged ·
no 1500 tin is different including fan housing
All easily over come tho for it to fit
Stephen62 ·
car is 6v, but if I go this way I would change to 12V
I have heard that the 1500 is wider than the 1200 ?
ian.mezz ·
I have a 1600 in a 54 bug
