irs camber adjustment
https://forums.aussieveedubbers.com/threads/89242/irs-camber-adjustment
bugzla ·
ive just incressed the hight of the back of my manx and have found that the drivers side has a lot more camber the the passenger side any body come across this before and have found a solution
stevo
adjust the rear end camber and replace the rubbers as they will probally be worn and need attention
bugzla ·
but how do you adjust the camber ? the rubbers do need changing thou they were a bit ratty looking
have a look at he book called VW for the complete idiot
It may explain easier than i can
you need to set the car level and use a bubble protractor to measure the angle on the trailing arm
YES u need to replace the inner n outter rubber bushings as this also effects the camber if they are buggared
The camber is adjustable by which ever angle you set the rear end too there are inner n outter splines whic hmake the adjustment
do u have a local VW shop that may be able to reset the rear end for you
Its hard to explain but the spring plate and trailing arm are able to scissor where they meet.
To get maximum positive camber you need to loosen the bolts on the spring plate and trailing arm and put a jack under the shock mount, this will make the trailing arm lift in relation to the spring plate giving maximum positive camber.
Think of it like this, if you have negative camber the top edges of the spring plate and the trailing arm will look like an inverted shallow V, in positive camber you will have a shallow inverted V.
There is not a lot of adjustment so if the bushes are worn they could be causing issues, particularly the inner ones on the pivot.
bugzla ·
thanks guys ill save and buy the bushes and adjust
SuperOwen ·
I had a similar issue, got my ride height dead even with all new bushes etc both sides but camber was out. I used south coast suspensions at kirrawee in sydney and he managed to get it all squared up the way steve described. There was a couple of degrees of adjustment in there from memory but finding a competent wheel aligner isnt quite so easy!
oldtub356 ·
Owen, I think that may be EAST Coast Suspensions (down South, in Sydney) _ David Falson?
http://www.eastcoastsuspensions.com.au/
He ran a particularly well sorted 356A on the dirt track circuit at Amaroo, in another lifetime.
Speaks VeeDub fluently, both road and race.
Do you remember what it cost to get your IRS sorted at the time??
Lance.
MickH ·
bugzla wrote:thanks guys ill save and buy the bushes and adjust
Come over and grab some...theres a few sets here somewhere......😂
