1) 1968 bug adj. spring plates $180
2) 6"x14" 4 stud steel rims & 1/2 worn tyres $150
3) D/draught Weber carby(new) 44mm twin choke DCNF-107-7D $80
4) '68 bug taillights (pr) $10
5) '62 & '63 bug speedos $10ea
6) "72 bug irs rear left assembly $20
7) '72 bug l /frnt shk assemb $20
8) '71 Kombi tailgate(comlplete/white) g/cond $50
9) Bay engine lid(yr ?) 950x340 g/cond $20
10) Bay b/j bus laser cut beam side plates(copied KCW) 10mm with dual bolt pattern(suit Split/Bay) $90 pr
11) Link pin bus laser cut side plates (copied KCW) 10mm $90 pr
12) SUBARU (EJ18-EJ25) conversion kit.......adaptor/bolts/flywheel/220mm pressure plate/clutch disc and FREE EJ18 motor $400
Located:Quaker's Hill (2763)
Call;John 0418164059
Prefer local pick up/ inspection......need space & $$$ to finish '67 splitty....
dr strapp ·
😵💫 bump
Aussie Dubbin ·
So, who did the Subi conversion gear? sn't the 18 an EA18 and the EJ20 different?
DylanTheDubber ·
no you can have a EJ18 it is out of sport wagons and early imprezzas. The EA81 is an older 1.8L
From Dylan
vassy66T1 ·
PM sent
dr strapp ·
In reply to Aussie D....this motor is an EJ 18 not an EA...I bought the complete setup from Vicsbahn together with a gearbox (it came out of an Oval being brought back to stock) to fit into a project,which won't happen since my '67 bus project is now allconsuming and dollar hungry. The adaptor is a John Sherman (0755377770) setup, and he confirmed this fits ej18 through to ej25.... price is negotiable, as I need garage space.......hope this helps....
