I have lots more vids of our adventures at Bathurst Hillclimb this year.
I will post them up one by one in the coming days.
This is one of myself off the start line in the rain on the Sunday which was Mountain Straight Hillclimb. It gives me goosebumps just watching how deep i go before braking into Griffins bend in the rain.
Cheers Col
dangerous 路
You are a mad man Col! 馃槀馃憤
colin 路
Here is Heath in the rain, same day.
Yes Dave, another madman, i am not alone LOL.
Cheers Col
colin 路
This is myself at the start of the Esses Hillclimb, just touching the rev limiter in first gear.
Here i had it set at 7800rpm.
Cheers Col
type3ute 路
Hi Colin
Are you running at Cooperabung this weekend.
Cheers Jukka
colin 路
type3ute wrote:Hi Colin
Cheers Jukka
No mate not this weekend.
The next state round event will be 03/07/2011, allthough this may sound a little precious i will not be running unless there is a vast improvement in the track surface.
There was six cars hit the tyre wall last year causing a lot of damage as this is a fast sweeping right hander and the rocks were coming out of the bitumen.
If you run let us know how the surface was.
Cheers Col
colin 路
Here is me off the start of The Esses Hillclimb and around the first corner.
Cheers Col
colin 路
Here is the famous dipper section of the track.
In the footage i have just changed down to third gear from a 4th gear approx 130k,s approach, before the left kink then up the dipper and around the left hander.
You can get a feel of how steep this section is, the car rises quickly out of the dipper and unloades the rear shocks so it,s a little hairey.
Heath data logged 93k,s through the dipper and as i was .24sec of his overall time i guess i,m doing the same, allthough it doesn,t look that fast trust me those walls move quickly.
Enough dribble enjoy!
Cheers Col
vw54 路
some nice runs there
Was Larry with you ??
colin 路
vw54 wrote:some nice runs there
No, Larry works alot so he couldn,t make it.
Hopefully he will come to a few Hillclimbs later in the year.
Cheers Col
Craig Torrens 路
a relaxing sunday drive......I need to drill holes in the muffler for some more sound 馃槀
colin 路
Craig Torrens wrote:a relaxing sunday drive......I need to drill holes in the muffler for some more sound 馃槀
One very fast quiet Sunday drive!.
Thanks for sharing.
Cheers Col
colin 路
This vid is coming out of the famous Cutting, were you must exit as fast as possible to get a good run into Sulman Park.
Cheers Col
colin 路
This vid is again The Cutting, were Greg accelerates hard out, and the poor little 1916 reves it,s t--s of up to the rev limiter.
Nice flat change Greg.
Cheers Col
colin 路
Heath out of The Cutting.
I have now uploaded all my racing footage. Hope you enjoy watching as we all had a great weekend of fun and racing.
Cheers Col
vassy66T1 路
Thanks Col
Craig Torrens 路
Cheers Col
Wow that has power.....listen to it just wheel spin all the way around the corner !
Great Vids Col.....see you at Canberra round ?
colin 路
Cheers Col
No mate, went last year but it,s a hell of a long way from Tamworth.
Got a few little probs at the moment so Tamworth should be my next outing.
Cheers Col
type3ute 路
Hi Col
See what you mean about last corner. Only one car hit the wall this weekend and that was due to the wet track. Most of the loose stuff got torn off by the V8s. A local in his street SS commodore did a 28sec run. He got 2nd outright ahead of some specialized Hillclimb openwheelers and allwheeldrive Evos and WRXs. Took some footage of my third run but it started to rain when we were lined up so was a bit slippery again. Cheers Jukka
cnfabo 路
gregs engine is mental,listen to that thing....yew......
hellbugged 路
thanx for sharing Col 馃憤
just found one of Gumley's supercharged type 4 wortmeyer 2010 @ Colingrove
dangerous 路
Cheers Col
I dont think that is a rev limiter.
Sounds more like float....must be like 9000!
