Fuel Starvation Issue - 1302
https://forums.aussieveedubbers.com/threads/89352/fuel-starvation-issue-1302
yortle ·
Symptoms:
I can drive the car for 20mins to 1/2 hour then if I have to stop & start i.e. traffic lights the car will stall. The motor turns over fine but doesn't fire. If I have a little bit of fuel & feed it to the carb the car starts fine and away I go again. What could be the cause?
Troy
My guess is some how the fuel is leaving the bowl
I would start with changing the pump
A cheap and easy check that wont break the bank
barls ·
could also be vapour lock, i use to get this in the other bug i had.
here one if you open the main just plug on the fuel bowl do you get fuel or is it dry?
beetleboyjeff ·
I reckon fuel pump - I had a similar problem, and that's what it was.
Check to see if there any inline filters and on a 1302 there is also cleanable filter screen in the tank, have look underneath car for allen key plug.
yortle ·
New fuel pump seems to have solved the problem.
Troy
