Aussieveedubbers · Help out a Dubber
vw beetle headlights
https://forums.aussieveedubbers.com/threads/89509/vw-beetle-headlights
vwbugsrule ·
Hey guys, got 2 headlights that i need to put back together on a 61 bug, i cant figure out how to fit the chrome, glass, the housing and reflection plate back together correctly... can anyone show me a diagram or give me clear instructions. that will be great thanks ❓
grumble ·
Fit the rubber seal to the glass,fit the glass into the rim with the Bosch or whatever logo at the bottom,fit the large reflector retainer to the glass and fit the spring clips 3 on each side,then fit the reflector to this with the park lamp globe at the bottom.The adjusting screws should then clip into the 2 rubbers on the reflector and the other rubber fits into the reflector retainer. this mounts the reflector and allows the reflector to pivot as you adjust the light.
vwbugsrule ·
ok thankyou very much good instructions. I wasnt sure which way it was meant to be turned, but was you said the park light at the bottom thankyou. 👍
