Manx windscreen frame
https://forums.aussieveedubbers.com/threads/89582/manx-windscreen-frame
resonic ·
I really need an alloy Manx windscreen frame desperatly. The one that came with my buggy is broken and does not fit the hardtop.
Please help...
1916baja ·
Where are you located?
Brad ·
I have them in stock and am located in Brisbane. If you want with without glass I can freight it anywhere in Australia.
Before you do that though. You say it will not fit your hard top. If you have a Manx and it has a screen chances ar that it will be the same screen which I sell. They all come from the same guy in America.
Please explain what you mean by doesn't fit, I also sell hard tops and usually when people say they won't fit it is because their screen is in backwards so the lip will not fit. If possible post pictures of what you have and what the issue is and you maybe able to save yourself some money.
resonic ·
in Brisvegas, on the north side. The crappy sttel one i have is 40mm to wide for the body, and at some stage has been bent which caused it to deform and crack on one side. Also i dont have a rubber for it and finding one to match will most likely be inpossible.
I know of a manx hardtop mould which i am hopeing to use to cast a hardtop, so a manx frame in theory should fit.
Brad ·
Ok well get a measurement of what you want width wise. That mold you know of is not a Manx Top and it will be to wide for your screen if you have a Manx screen. I will have Manx Hard Tops in stock when our first container arrived end of June 2011.
VDUBXTC ·
His buggy isn't a Manx brad. It's one of the sand???? made out of Tasmania
