Aussieveedubbers 路 VW Drag Racing
IDA help (previously) IDA love (now)
https://forums.aussieveedubbers.com/threads/89595/ida-help-previously-ida-love-now
fullnoise 路
More help requests later in the post.
I'm intending to run some IDAs because they're cool.
I've got some short SCAT manifolds and a CB Performance hex bar linkage which I just discovered are not a good combination.
The SCAT manifolds have the carbs 180 degrees out from where the linkage requires. The adjustment screws and float bowl plug face the fan. The linkage rotates to the outside rather than inside.
What's the best solution?
Plan A get CB Performance manifolds. But they'll be too tall and I don't want to modify then engine lid.
Plan B get CSP short manifolds. BUT they're $389 + freight.
Plan C stick with the scat manifolds and get a Berg GB 451 linkage which apparently works with these manifolds.
I hear short IDA manifolds are hard to find.
TIA CT
ian.mezz 路
http://forums.aussieveedubbers.com/viewtopic.php?tid=89039
offer him $20 buck 馃お
HS618 路
CT, You might try getting lugs welded on your current manifolds , drill and tap them suit to your studs, opposite to the current stud pattern to turn them around. If you have a look at some Berg manifolds asa guide, they already have this feature so that the carbs can be used either direction - H
dangerous 路
http://www.compcams.com/Technical/Catalogs/NP2009/pdf/page22.pdf
I think either making or welding adapter lugs may be the fastest option,
especially if you like acces to your mixture screws.
Welding will require remachining to keep flat where the gaskets go,
which should be easy for who ever drills and taps the new part.
matberry 路
I've done two recently with these manifolds, both we used the Berg linkage. I like the linkage so decision was easy.
modnrod 路
What about a simple cantilever? Use the good hex linkage you have now, but then drive a cantilever cross-over linkage from that to push the throttle blades. Easy to weld onto your manifolds a couple of pivots, and a couple of adjustable small heim rods.
Bit of mucking around when the Berg linkage will work though.
Dak-A-Tak 路
Why can't you turn carbs around but change linkages ends around or swap throtle saft around ? sorry about spelling
matberry 路
Can't do Pagey. (within reason)
IDA's only have one end for lingage/throttle stop.
Dak-A-Tak 路
Why can't take shaft out and turn around ? Is it the length on ends or butter fly slots .
hellbugged 路
get a berg linkage ya miserable miser
colin 路
hellbugged wrote:get a berg linkage ya miserable miser
Go the Berg linkage CT.
Straight out undisputed best around.
Bout time you IDAed your VW.
Now you can listen to the glorous roar all the way to Tamworth next month.
Cheers Col
Gracey 路
Have you considered this cable system: http://www.thesamba.com/vw/forum/viewtopic.php?t=420589&highlight=ida+linkage
I've been riding multi carb motorbikes for years and they all use cables and they work. If I was in the market for a new carb linkage this is what I'd go for.
fullnoise 路
Thanks for the replies everyone.
I'm warming to the idea of a Berg linkage despite being a miserable miser ; ) . I'll call them tomorrow and see if they have stock and can get the thing here in reasonable time. I've never ordered anything from Berg before.
Since the car is driven mostly on the street I'm quite pedantic about the mixtures being right. So having the mixture screws facing inwards makes sense.
I've always wanted to try a Berk linkage, oops Berg.
I tried swapping all the bits around as Pagey suggests but with no luck.
I also looked at the clever linkage suggested by Gracey which was tempting but doesn't suit the old-school flavour I'm sticking with.
Thanks everyone.
CYA CT
Dak-A-Tak 路
How about a early middle swivel set that pulls towards middle of engine ?
hellbugged 路
fullnoise wrote:Thanks for the replies everyone.
phone about this time of the day!
if they are in stock (which i think they are at the moment) it will be here by Friday. have the part number and your credit card handy to speed the process...................and don't forget to order your 5speed kit 馃槀
is it time for a welded fan while your on the phone CT?
http://www.geneberg.com/product_info.php?cPath=19_494_2979&products_id=1254
http://www.geneberg.com/product_info.php?cPath=8_230_2837&products_id=822
mactaylor 路
so are u on the books yet daimo? maybe the aus rep!
hellbugged 路
email from bergs this morning CT........
"On the linkage, yes we have them, I have made this run in silver and wrinkle black powder, as I find the zinc is really only a decorative finish. The heims are chrome plated and the top bar stainless, and they both look really good."
you want me to organise?
Brian 路
I don't like the Berg linkage set up , Its too difficult to sync the carbs with those bent linkage arms.
Stupid design IMO... as well as exe
colin 路
Brian wrote:I don't like the Berg linkage set up , Its too difficult to sync the carbs with those bent linkage arms.
Are you kidding!
It,s soooooo easy.
Cheers Col
fullnoise 路
I've got a few things cooking at the moment in my oval's mechanical makeover (More of a large casserole on low heat rather than anything from a microwave).
I must say thank you to all those who've posted their comments here.
I've been blown away by the help I've received from Rod Penrose, Henry Spicak, Marty Staggs, Alan Agyik and Jak Rizzo (Despite the latter having a subaru engine). They've all helped me above and beyond the call of duty tracking down and figuring out the parts I've been chasing.
I can see why I've been into VWs for two decades and still love it. The people in the scene are awesome.
Bring on the Tamworth Hillclimb, VW Nationals Supersprint and Warwick Drags.
CYA CT
Dak-A-Tak 路
whathaveidone 路
Thats the same a Morgan uses on hhis bug. I wouldnt mind a set for mine
fullnoise 路
Hi Peter,
Thanks for the images. I tried a Scat Linkage yesterday and it seems to work pretty well.
As usual I had to make a few mods. I had to clearance the underside of the alternator stand a few mm. I also had to shorten the arm to the 1/2 cylinder side by about 12mm (A further 8mm will be needed to put the locknuts on). This required drilling and tapping a deeper thread into the arm.
The linkage is a bit stiff and I'll have to build a bracket for the return spring, but I should be able to get it to work. Now, to finnish porting the manifolds and put a kit through the carbs.
colin 路
Love your work CT.
Nothing looks cooler than old school IDA carbs.
I think with your car theme it,s a perfect fit and you,ll love the roar when you mash the throttle.
I,ve got heaps of jets and chokes so let me know if you need anything.
Cheers Col
fullnoise 路
Nice engine bay Colin. Greg was amazed that when he arrived at the Bathurst Hillclimb that you had time to polish your wheels. I assured him that you've got much more time than that. Just look at your car. It's a work of art.
I think it took 3 hours a side to port and flatten the mating surfaces of these manifolds. Thankfully they're done.
The gearbox and engine go back in on Friday with Jak Rizzo's help. I doubt I'll get the thing started next weekend though. There are all sorts of tricky details to sort. They somehow stack up. Whenever you modify just one thing you end up having to modify half a dozen others.
fullnoise 路
They really are baby ports.
colin 路
Can,t wait to see and hear your car with all your mods done.
Tamworth Hillclimb is gonna be a VW Beetle invasion, how cool!
I do love getting down into my cave as my wife calls it, better than pissing it up the wall at the pub.
She always knows were i am.
Cheers Col
colin 路
fullnoise wrote:They really are baby ports.
With sharp teeth!
Cheers Col
fullnoise 路
The engine and gearbox went back in the car today. But the IDAs are raising a few questions.
I managed to inspect the shaft bearings and accelerator pump pushrod. They're in good nick. The bearing grease was dry so they will enjoy the new grease I packed them with.
Can somebody help me with a specification for setting the bottom and top float levels?
Also I think the rebuild kit I got was crap. The needle and seat are completely different (useless), the base gaskets are too small and the stud holes are too close together, it comes with washes that don't fit anywhere and there are no O-rings for the fuel pump squirters. The top gasket fits perfectly though.
Are there different kits for different versions of IDAs?
What gives?
Should I have faith in fibre washers keeping the banjo fittings fuel tight?
Thanks CT
Brian 路
I have seen those Banjo fittings shake loose and leak , you need to keep an eye on them.
Those needle valves are wrong . I do have the float level guages at work , if no one else posts them up I will.
fullnoise 路
Hi Brian,
Thanks for the advice.
I'm going to check the top float level with a cardboard template. I'm going to check the distance to the needle and seat from the top of the carb with a tread depth gauge. Then I'm going to use copper washers for the banjo fittings and lock wire the bolt so it doesn't come loose.
Cheers.
ian.mezz 路
I got my rebuilt kits from my local autopro shop , they didnt cost much.
this link may help
Understanding what transition is and how it works in the Weber IDF and Dellorto DRLA carburetor. These principles do apply to some other models with similar architecture, such as IDA, DCNF, DCOE, etc.
http://www.carburetorclinic.com/setup.htm
fullnoise 路
The engine idles smoothly and pulls hard right through the rev range. I was surprised. The IDAs feel almost the same as the IDFs. I'm a happy camper. But I'll see how they go in Sydney traffic on Friday. Then on the freeway to Goulburn. Then at Wakefield Park on Saturday. They're so cool. Fingers crossed.
CYA CT
Bizarre 路
IDA's rock 馃憤
Golde60 路
From the original post.....
fullnoise wrote:I'm intending to run some IDAs because they're cool.
That sounds like a good idea to run the berg linkage.
Coolest old skool set up going around is the look of idas and a berg linkage imho
