Wide rims QLD
https://forums.aussieveedubbers.com/threads/89631/wide-rims-qld
1916baja ·
Hi guys, I have a set of 4 stud wide 14" rims, rears are 10" wide and fronts are 7" wide, Both have 120mm back spacing, They have tyres on them but they are pretty shot. I was planning to use the rears on my drag car project but i have now realised there is no way i'm going to get 10" wide rims under the rear of the car and 14 x 8" slicks are pretty hard to come by, I am interested in trading this whole set of 14" rims for either 2X 15X6 or 2X 15X8 4 stud rims with roughly the same backspacing.
PM or leave a message on here.
Mick
Mt gravatt 4122
0439002870.
1916baja ·
Bump, someone must want some mega wide rims for their beetle!
bushed ·
ET = ? (backspacing) for what type car I have some poloshed 4stud 15 jellies with 80% rubber std vw ET
any pics...may help Mick
B
mackaymanx ·
E.T=Backspacing - 25.4(Rim Width + 1)/2
E.T and Backspacing in Millimetres
Rim Width in inches
1916baja ·
Ok guys, I have re-measured and have some photos of the wheels... I first thought they were 10" wide but i may have been wrong, you tell me... they are 14" vw beetle,karmann,type 3 wheels. 4x130.
I have measured the outside of the rim from the outer edge of the rim to the lug hole in the centre and the same from the back.
Rears: backspacing- 110mm
outside-115mm
fronts: backspacing-100mm
outside-70mm
I am not 100% sure on actuall rim width as i don't know where to measure it from?? but i guess if you add up these measurements you have, give or take:
9" rears
7" front
1916baja ·
Also, Bushed... I am interested in the jellies, what are the specs?
Mick.
1916baja ·
bump, I have found some rear wheels, so if anyone wants these the price is 50 bucks or type 1 parts... i need some running boards? 1970 swingaxle rear brake drums?? let me know what you have i'll tell you if i need it.
Mick.
