subi ground clearence in a T3Bus
https://forums.aussieveedubbers.com/threads/89696/subi-ground-clearence-in-a-t3bus
mjwcookie ·
Hi All. Just a quick question.
In an ej33 or eg33 conversion into a T3bus. what is the difference in ground clearance. I have noticed on many vids that it is reduced. I know that a shorter sump is used, but the beauty of the bus is the higher ground clearance. Can the engine be raised,say 5 cm if need be.
Mark
ahoogah ·
mjwcookie wrote:Hi All. Just a quick question.
Mark
Not much room to raise unless the engine hatch is modified.
I went with a smallcar sump,gives same clearance as tranny
and a nice bit of gear.
Dave.
Easier to shorten a sump by 50mm than raise an engine and transmission by 50mm.
mjwcookie ·
Thanks for the advice.
Mark
seagull ·
Check this site out Mark
http://www.rjes.com/html/sumps_.html
Brad ·
Here is a picture of a shortened sump for an EJ33 in a Bay Kombi. From memory we gained about 70mm.
Make sure if you are getting one that it is for an EJ33 not an EJ 20 / 22. I haven't seen anyone producing an EJ33 apart from Custom Offroad Components.
ahoogah ·
Smallcar do a sump for eg33.
http://www.smallcar.com/index.php?dispatch=products.view&product_id=29947
mjwcookie ·
Brad. very nice looking Job. Did you do it yourself? How difficult was it, if you did. How does the ej33 cope with the vw box? gear ratios etc.
Mark
