Distributor Pinion
https://forums.aussieveedubbers.com/threads/89830/distributor-pinion
Baja Dan ·
Hi, It seems that the distributor pinion has been installed incorrectly for my engine. It is a 1600sp. My question is. Is there a way to remove the pinion without splitting the case so I can line it up properly. Thanks
1916baja ·
You can get a distributor drive puller, it's like a T handle tool thing, I actually borrowed one from mick motors a few years ago, Just left a 50dollar deposit and picked it up when i took the tool back.
Mick.
Even with the tool they can be a mongrel to get out. How far out is it?
Baja Dan ·
Hi Steve, It comes out about half way I guess but then feel as if it is hitting something solid. I going to try and get hold of a tool to make it a bit easier to handle.
The fuel pump and its pushrod guide need to be out. If still only coming partway out, look down the fuel pump hole and with a long screw driver, keep the small shims down on the seat of the dissy drive. The shims jamb into the brass gear and stop the drive.
I have a puller if you need one
Baja Dan ·
Thanks Matberry, got it out today and realigned it but now it is backfiring through the exhaust. Thought it may of been the carb so put a another one on but not different. Any ideas.
First thought is triple check the firing order asuming the back fire is during acceleration and quite bad/obvious.
Baja Dan ·
Thanks mate. I put a new dizzy on today, an electronic ignition swap. It seems to have stopped while idleing but now it backfires under accelaration and when you hold the throttle down at constant revs it seems to break down and start to backfire and die. Just to make sure on firing order it is 1432 right.
Yep, 1432 is correct, have you a multi-meter to check plug lead resistance, are the plugs fresh???
Baja Dan ·
No plugs not fresh might go get some tomorrow what do you recommend just in case the ones in there are not the right ones. What should the the leads read at. Thanks for you help.
If the heads are original type the plugs should be Bosch W8AC. Plug leads should be wire/copper core with resistive ends (stock bakerlite type) as the coil and distributer rotor are designed for this type of lead, not a silicone lead. Resistance should be between 1k and 5k ohms each lead, coil lead zero and rotor 5k.
Baja Dan ·
ok Pretty sure that the heads are stock but the coil and distributor are not. I have just put on a flame throw electronic ignition and but it was already backfiring before that. The coil is a bosch gt I think and the leads are silcone but I believe these leads have been on for a bit. I looks to me as it is running rich as the plugs and the exhaust are sooty black. I change the carb to another but that didn't fix it so I went back to the original. The carb is a H30/31 PICT jetted to 120. I was thinking it was running lean that why it was backfiring but the sooty black plug etc don't surport that idea. I guess maybe if the plugs are wrong which I think they are as they are not what you said above are the plugs that are in it, it may not be burning the fuel properly they igniting in the exhaust.. I believe the motor is a 1600 SP. It also converted to 12v.
Smiley ·
Baja Dan wrote:ok Pretty sure that the heads are stock but the coil and distributor are not. I have just put on a flame throw electronic ignition and but it was already backfiring before that. The coil is a bosch gt I think and the leads are silcone but I believe these leads have been on for a bit. I looks to me as it is running rich as the plugs and the exhaust are sooty black. I change the carb to another but that didn't fix it so I went back to the original. The carb is a H30/31 PICT jetted to 120. I was thinking it was running lean that why it was backfiring but the sooty black plug etc don't surport that idea. I guess maybe if the plugs are wrong which I think they are as they are not what you said above are the plugs that are in it, it may not be burning the fuel properly they igniting in the exhaust.. I believe the motor is a 1600 SP. It also converted to 12v.
120 sounds like to small a main jet. I'd be going to at least 130, maybe 135.
Smiley 😎
Baja Dan ·
Ok I think it is all sorted. Thanks smilely I was thinking that it was running lean but the plugs are black and sooty so I didn't want to put a bigger jet in just yet. Anyway replaced plugs, leads, and coil to one for electronic ignition and she seem to be back to normal although I think the float level or needle may be sticking so will give the carb a overhaul and hopeful all good, then if it is running lean then I will change the jet. Thanks again for all the help guys.
