Super1302 wrote:anyone done a mod where you could run a single wiper arm with an upgraded wiper motor for the front windscreen
i would like to do some time in the future, is it possible?
if not at least a better wiper motor system than what is standard as intermittent would be good too.
Paul馃槑
Well, I'm thinking You have a SUPER BUG 1302 with the flatish screen... [not really flat glass]
I don't know why You would need a better wiper motor?? but the linkages all need lubrication... plus they could be badly worn?? [bushes]
New wiper arms with good spring tension may help along with new wiper blades...
OR
the only wiper system You could experiment with for a mono wiper that I could think of... is the early fords like XB XC falcons where one of the wiper arms has an arm connected near where the shaft comes out...
and holds the wiper blade so it wipes right up to the edge of the screen when the blade is actually vertical. but whether You could adapt this system for one wiper...
I don't know... and as Joel suggests...
these days if Your car came with two wipers....
Then Your car shall have two wipers....
If its good enough for the V8 supercars to have a mono wiper
