when i rebuilt the fuel pump i forgot were the fuel line goes on the pump馃お one inlet is high and one is low witch one is the fuel line from the tank go
thanks
hellbugged 路
tank on the bottom one
Joel 路
If its the bolt together style pump what Hellbugged said.
if its the round metal top kind then other way around.
Just have a go, you got a 50/50 chance 馃槀
RATAFIED 路
thanks its the bolt together
cheers 馃槈
vlad01 路
actuate it and feel which line blows and which sucks.
if its already on the motor, turn the motor and feel for the same as mentioned above.
RATAFIED 路
i couldnt fell anything when the misses was kicking it over ,one i can blow through and the other feels like it is block
vlad01 路
the one you can blow through is the input (aka tank side)
