Aussieveedubbers 路 Tech Mods and Frequently asked Questions
speedo mph to kph
https://forums.aussieveedubbers.com/threads/90015/speedo-mph-to-kph
acemarc 路
Being born in the metric era I am more used to kph than imperial. Add to that the astounding array of speed limits, I am looking for a decal or another idea as to how to change my speedo over to kph readings. I know you can buy a new one but there are around 300 reasons why I wont do that.
Buger Gary 路
hi there, with mine i went to a sign writer that does the vinyl stickers that are cut out with the computer cutter and got them to do a heap of numbers in a fluro colour.I then dismantled the speedo and stuck them on the backing in the right places then put it back together.You can convert the m/h to k/h to help put them in the proper place.i only did the 60, 80, 100 and 110 ones and placed them just under the m/h numbers so you could still see both.I have seen the stick on ones that go on the outside of the glass but if the glass moves your going to be wrong lol.
cheers 馃樀
Paulc1964au 路
Gary,
Can you post a pic would be interested to see
ian.mezz 路
just buy a navman or tom tom GPS as the vw speedo is probably out any way
zocstar 路
I've got one for a type 3 with a decal on it cheep if you want it just pm me and we can work something out.
barls 路
i got some stickers made by warb, ill check when i get home to see if i still have any left
BRUTUS 路
1.609344
If you don't want to spend much, you can cut out small pieces of sticky-label paper, and place them at the correct points on the dial.
zayus 路
Hello,
A conversion table is very useful - http://calculator-converter.com/converter_mph_per_miles-hour_to_km-hour_calculator.php
You could stick a post note to your dash.
Listing, say, the important speed limits,
EG:
km/h = mph
40 = 25
50 = 31
60 = 37
70 = 43
80 = 50
90 = 56
100 = 62
110 = 68
150 = 93
250 = 155
300 = 186
Once memorised, remove the post it note.
馃檪
DylanTheDubber 路
Punch in vw speedo in eBay Theres one for sale it's up to $55
From Dylan
68AutoBug 路
acemarc wrote:Being born in the metric era I am more used to kph than imperial. Add to that the astounding array of speed limits, I am looking for a decal or another idea as to how to change my speedo over to kph readings. I know you can buy a new one but there are around 300 reasons why I wont do that.
looks like You have a type 3??
not a beetle ??
speedos are different looking...
PS: would like to see the speedo with flouro stickers attached..
68AutoBug 路
Buger Gary wrote:hi there, with mine i went to a sign writer that does the vinyl stickers that are cut out with the computer cutter and got them to do a heap of numbers in a fluro colour.I then dismantled the speedo and stuck them on the backing in the right places then put it back together.You can convert the m/h to k/h to help put them in the proper place.i only did the 60, 80, 100 and 110 ones and placed them just under the m/h numbers so you could still see both.I have seen the stick on ones that go on the outside of the glass but if the glass moves your going to be wrong lol.
cheers 馃樀
any chance of a look at Your speedo... GARY
the outside stickers don't look good in My opinion... lol..
but so long as they save You money in fines... lol
Ian
I have a GPS but rarely use it.. and NEVER check the speeds on it anyway... [should have when I got radar gun police going to nationals last year] as I don't believe I was speeding... Lee
