cam070 wrote:I know there are jacking points on either side of a bug just in front of the rear guards for use with the factory issue jack, but where would be the best places to jack using a trolley jack, and where would the best place to locate axle stands once the car is up?
I always use the front torsion bar tubes to lift the front in the centre and put axle/jack stands either side...
on the rear I usually jack the rear up using the engine/gearbox mounts cross member to jack the car up
and then place axle/jack stands under the torsion bars
don't place the jack under the engine or gearbox...
PS: the jacking points are really only for the VW jack in emergencies...
