As some of you dubbers out there know, i am restoring a 1961 bug. I have learnt a lot about the body work that needs to be done from all sorts of people. (some overseas)
If you are planning on repainting your car I suggest you read the following.
GO DOWN TO BARE METAL.
If you just sand the paint that is already on the car, there are going to be lots of contours, lumps, and bumps. It will take ages for you to sand those flat and smooth. Remember it's the paint prep that makes a paint job look good! Bare metal is one flat clean surface.
What is the best way to get your car down to bare metal?
THE WAY I HAVE BEEN DOING IT FOR THE PAST YEAR
Paint stripper !!!! it is the best way to get your VW down to bare metal. Simply apply the stripper to your paint and scrape it off.... this may take a couple of coats. Then sand your metal down with some wet and dry paper... i start off with 80 grit and work my way down to 360, 800 then 1200.
Why wet and dry sand ?
This will get your metal down to a smooth flat surface after paint stripping, once you cant see anything but bare metal, there are no imperfections. Remember to sand with a FLEXIBLE block due to VW's curvy panels.
Why not sand blast ?? won't this be easier??
Go ahead if you want to ruin your car. Sandblasting is a NO NO when it comes down to VW's. From the factory they where penetrated with a mist which stops rust, you do not want that coat to go. Sandblasting actually cuts into the metal which wipes out your penetration coat. Paint stripping will not do this, it will only take your paint off. Also once your car is painted, in some areas the paint will not stick as well, this is most likely to happen in little tight corners and areas. In order for paint stripper to ruin your penetration coat you will need to leave the stripper on the metal over night. I have left my car in bare metal for almost a year nowl..... and the whole car only has 4 tiny areas of surface rust. (due to me sanding in those spot a bit too much)
Now I am telling you this because i don't want any more people to go through the stress and pain when it comes down to getting your car back from paint and seeing imperfections. You will not get any sort of imperfection if you Bring "ER" down to bare metal.
I have done this before, i took a short cut because i wasn't bothered to take my panel down to bare metal, i thought it would be ok. And what happened ??? MY SURFACE WAS LUMPY, BUMPY and FULL OF IMPERFECTIONS, and it also took 3X longer to sand a surface smooth than to paint strip it. I thought that the surface was smooth... but it actually wasn't. It takes the smallest elevation of paint to ruin your finished product.
Some other little tips are:
For small tight areas that have paint still stuck in them, use a drill with a wire wheel, this will take any loose paint off your car and doesn't scratch the surface.
Hand sanding is better on curved surfaces, using a belt sander and something like that can wear down your curvy piece of metal and make it flat. Leaving a wonky surface.
You don't have to go down to bare metal in places you cant see. I am leaving paint on my heater channels and wheel well areas which can rust, having a GOOD SOLID paint as a base will be a good protective surface against rust. These areas will not be seen and is ok to not be totally perfect.
Hope this helps you Guys out there and understand my point of view. I know how it is like when you haven't got the time, but if you want to do something properly this is the way to do it. But otherwise if you don't really care and want the car done quickly then sand blast it. I would rather start from bare metal than having a pre painted surface. A show winner will only come from the amount of time and care you have put into your preparation.
I am free to answer any questions.
Anthony.
vwbugsrule ·
