Hi all, i'm working on fitting a subaru ej22 to my vw bus trans.
For doing that i need an adaptor plate. i have and agaptor plate wich fit the old models of subaru engine (ea), is there any way i can modify it that it will fit the ej enigne?
Ben386 ·
Do youself a favour,get a bellhousing.Speak with Richard Jones of RJES.
ahoogah ·
matan stolero wrote:Hi all, i'm working on fitting a subaru ej22 to my vw bus trans.
I think you'll find all e series are same pattern.
rocknrob ·
nope...no way it will fit however if all you need is the plate(you will need flywheel too) i could help you out with CAD drawings for laser cut
seagull ·
Fail rob I have a 1 x adapter plate only left here lazer cut
$70.00 + $25.00 post
rocknrob ·
seagull wrote:Fail rob I have a 1 x adapter plate only left here lazer cut
you won't beat that...laser cutting alone cost me $120
geez Neil tempted to buy that as an investment😂
ahoogah wrote:I think you'll find all e series are same pattern.
Nah they're mongrel things, EA81 is different to EA82 and both are different to EJ.
Subaru got it right and made all EJs the same
ttriebler ·
Only 2 bolts different on an EA to an EJ. You can modify to fit. But why bother. Do it right and get Seagulls.
seagull ·
Its here Rob
I have cheap * New * turbo 2.5 ltr pistions & 207 / 257 con rods for sale as well ( there in the for sale section )
PS There is a nice small Toyota water to air inter cooler as well
rocknrob ·
Neil you are like a salesman for the devil...i shouldn't listen but i am interested in the water to air....i am supposed to be spending money on my house!
matan stolero ·
Thx all, so from what you said it won't fit. i thought about building an adaptor plate between ea to ej bellhousing and solder it to my adaptor plate, that would fix the depth difrence between the ea and ej (12mm) and fit to the ea patern on my corrent plate, what do you think about that solution?
seagull can you please email me with some detail i may be itrested on youe plate.
seagull ·
do away with the adapter plate you have EA
Just fit a EJ adapter plate, these are 12mm thick
PS ( we have no idea were you are located so please fill out your profile ) also you dont have the link in this area so we can not email you
Postage is in Australia 🙂
matan stolero ·
ok, so all i have is getten a ea to ej adaptor. any ideas where can i find a sketch of that adaptor?
seagull updated my info on my profile.
ahoogah ·
matan stolero wrote:ok, so all i have is getten a ea to ej adaptor. any ideas where can i find a sketch of that adaptor?
