Rear suspension differences
https://forums.aussieveedubbers.com/threads/90177/rear-suspension-differences
donn ·
Are the rear suspensions from a square and an L bug basically the same except that the square simply unbolts from the pan?
do You mean a squareback type 3?? Donn
[type 3 variant]
the early ones would have been swing axle [5 stud wheels]
and the later ones would be CV joint rear end [IRS]
Sides ·
Type 3 IRS is basically the same as Type 1 IRS, yeah.
Squarebacks had heavier torsion bars and double spring plates for carrying a load, but the parts from one will swap across to the other no probs.
My 68 auto beetle has IRS with twin side torsion plates
waveman1500 ·
As Lee says, some Beetle IRS systems had double spring plates and some had single. Mine is an S bug and has single spring plates.
