Thanks for the post 555bug but I really want either a 3 or 5 rib as I dont have the legs for off road with a 2L box.
Caroneten ·
Would more than likely have one of each. Im in QLD though just outside Brisbane
BJ
Klaus ·
I've got a 1600 3 rib box $150 wollongong
baghall ·
Klaus wrote:I've got a 1600 3 rib box $150 wollongong
Gidday Klaus thanks but can you tell me it's condition. Certainly interested if condition is good> I can't afford a rebuild.
Klaus ·
had it in the bus for blueslip no noise no crunches oil is clean was out of a 71 just changed to 2ltr box for freeway cruising
baghall ·
Sold Klaus😎
Just not sure when I will be able to get down and pick up at the moment. Probably be in 2-3 weeks.
I still don't have car back on road 🥲 but am getting close. Though still waiting on brakes.
Klaus ·
how are you hooking it up ? using bug axles or changing to kombi cv pattern on the stubs? or transplanting a complete bay torsion housing into the baja?
PAZZAN ·
ive got a 5 rib kombi box and axles and stub axles for sale nsw lanecove ...Paul 0407733212
baghall ·
Gotta convert the pan to irs and am gonna use T2 CVs and then if they fit T2 stubs with upgraded disc brakes so I can change the bias to the rear more. Also gotta make up a mount so the box mounts into the frame horns. I just hope I know what I'm doing!
baghall ·
PAZZAN wrote:ive got a 5 rib kombi box for sale lanecove ...Paul 0407733212
Thanks for the offer PAZZAN but have told Klaus I will take his, but will keep it in mind if it doesn't work out.
PAZZAN ·
ok
Klaus ·
doesnt bother me 5 rib might be better n closer I like to hoard as i have 5 or 6 of these boxes😂, why not just use an early 1300 box converted to irs or do you need the strength
baghall ·
I need the strength as currently running 31s on rear and already chewed out 4th on 1 box. Do a bit of off roading whenever I get the chance.
So do I take a 3 or 5 rib. Prefer the 5 rib for the road but 3 rib for off road?
manxed ·
If all else fails have a 1600 / 3 rib Kombi IRS 'box - hasn't been run since rebuild.
Thanks manxed but a bit far to drive up and pick up.
Actually my mechanic reckons it is cheaper for me to build up a bug box for offroad than to convert a kombi box to fit a type 1.
V-Dubber V2 ·
hay Klaus, how much you want for a 5 rib Kombi box IRS ? cheers
Klaus ·
no 1800 boxes but have a 2ltr that needs a rebuild $400 (noisy )
