The trouble with Country Buggy panels is that they were (almost) flat, and flat is a very hard thing to get them back to. Any kind of dent at all represents a “stretch” of the metal. Country Buggies are utilitarian so they’ve all been climbed on and had materials thrown in them. Mine, KO813 only has a few straight pieces of metal, and most of them have holes that need welding up.
This weekend I’ve been experimenting with the alchemy of metal shrinking. I followed the instructions from here:- http://www.carrepair-1950.com/shrinking-sheet-metal.htm
It works great. After beating the dents out you will always end up with a bulge, and using this technique it can be disappeared. I used an Oxy torch but I expect a carbon arc attachment on a welder would do, anything that will make it red hot.
Now, this bloke talks about getting it so straight you don’t have to use any filler. These panel beater blokes know some secret squirrel trick that I don’t know, that’s for sure. Anyway, hope it helps someone out.
Tony
bevoracing ·
