dubnbass ·
i have a 71 squareback. would a semi-auto box fit into it? also how does the shifter setup work is it the normal H type pattern?
https://forums.aussieveedubbers.com/threads/90206/semi-auto
dubnbass ·
barls ·
pod ·
dubnbass ·
dubnbass ·
barls ·
dubnbass ·
waveman1500 ·
Smiley ·
There's absolutely nothing wrong with a correctly set up Semi-auto car.waveman1500 wrote:There is no possible reason why you would bother. The Type 3 auto and the manual transmission are both better than the semi-auto. If you think you want a semi-auto that badly then make sure that you test drive one first to see if you still feel the same way!
dubnbass ·
Yes,dubnbass wrote:i have a 71 squareback. would a semi-auto box fit into it? also how does the shifter setup work is it the normal H type pattern?
dubnbass wrote:ill probably stick with my auto then, seams like alot of work.
dubnbass ·
