Hi guys just had a 1916 built and was wondering if any one else out there would know what sort of horsepower i might expect from it . IT made 86 hp at the tyres yesterday , was hoping for about 100 but maybe i was expecting too much, any help would be appreciated , thanks
Sides 路
Hey welcome to the forum, but man, that's like asking how long is a piece of string !!!
馃槈
Previous incarnation of my engine was 1916, 8.95:1 compression, 40x35 valves, cam between a Engle 110 and 120, mild porting job, 44 IDF's and it got around 80hp at the wheels.
Current version is still 1915, same case, crank, pistons, barrels but new heads, 11:1 CR, 44x37.5, FK87 cam, wedge ports, tall manifolds, dry sump. Pretty wild all-out-race motor really. With 44 IDF's and various vents, jets etc it's pulled 119, 125 and 132hp at the wheels. Converted to Haltech EFI and that climbed to 142.6hp.
So... depending on what you've got internally, somewhere between 80 and 140 is about right.
What did you ask your builder to build, and what does he expect from it ???
Aussie Dubbin 路
Combination of parts, whre do you ant your horse power? How long will it last before it breaks, maintence, Revs???
waveman1500 路
86hp at the wheels should definitely get a bug moving! Don't start to get too disappointed until you've driven it! 馃榾
fish26 路
You should be getting somewhere around 240HP, like Johannes from JP Motorsport on this video
Na only kidding 86HP is not a bad # depending on your combo, tell us more.
ian.mezz 路
65HP is good for a base street 1916 馃槉
86 is better 馃槉
fat-attack 路
i reckon 86 is a pretty good figure. What are some of the motors specs?
Ollie 路
Before falling for vw's I was a japspec guy and, thanks to publications such as fast fours and rotarys, I thought anything under three thousand horsepower lame.
80+ hp In a Vw will certainly give many people a shock when you plant the go pedal 馃檪
Joel 路
Is this for street or strip?
Power to weight, low gearing and good traction is the VW advantage, like the others have said 85hp at the wheels will make for a quick vw on the street.
I was getting that with my supercharged 1600 and it was a blast to drive, my supercharged 1776 and the subi are good for about 100hp at the wheels and in an overweight Lbug thats makes for 0-100 in 7secs which will make alot of V8s upset.
Doesn't take much to get these little cars cranking, just ask Rose about her 1916 bug embarrassing the V8s at the strip 馃槀
ian.mezz 路
yeah at Warwick VW 1/8 mile drags, just about all of the 1916 bugs did 10-11 sec passes
LIFE IN THE LOW LANE 路
2.0L type 4 in my Kombi with stock CR, 40mm dell's, custom exhaust, ported heads, cam, and lightened flywheel made 79.8hp atw. engine is long in the tooth(365000+km) but it pushed my bus down the 1/8 in 11.35@ 58mph. Bus is a fair bit heavier than a bug so 86hp should be a bit of fun to drive!!
1916baja 路
I'd be interested in some specs too... We are currently building a 1916 also. And sides, if they are the heads I have now they are 40x35's..... They have had some work done now though. 42x37.5's would be nice!
Sides 路
Doh - my bad !!!
馃槉
Thanks Mick - have fixed up my post.
Craig Torrens 路
There are not very many 100+ HP beetles driving around (regardless of cc capacity) so 86hp should make for a quick street beetle. 馃憤
As a comparison: A Pobjoy Base 1916 is around 75-77hp (Kadrons, standard heads etc).In a 800kg beetle you will get down the quarter in 16 flat (high 15's possible) at 80mph. A Subaru liberty with the 3lt 6 cylinder boxer motor and 6 speed will get a 15.7sec...........and yes I have tested this 馃槈
Don't get caught up with the dyno figure, it really means nothing unless you are using it for measuring a change that you have made or directly comparing it with another car that was run on the same day.
macdaddy67350 路
thanks heaps for the replies i'll get all the info on my engine and post it , i can tell you that its got a 110 engle cam empi heads with twin 40mm empi carbs and its in a J&S beach buggy that weighs about 660kgs
Craig Torrens 路
then that HP is good 馃憤
fish26 路
That's in the range of 130HP/tonne........very good fun!
fullnoise 路
My 1916 is 2/10th of second quicker over the quarter mile at Warwick with 96HP from a K8 cam than 99.9 from the previous W130 cam. Go figure.
I've taken my engine from 76, 83, 89, 99 and 96 all with the same block, pistons, carbys and compression. You can make a big difference with the choice of head, choice of cam and getting things like timing, exhaust, inlet manifolds and carbys right. There can be a nice art to squeezing out the horsepower as opposed to cheque book racing. Beside, it provides hours of head scratching entertainment.
86 is pretty good.
CYA CT
macdaddy67350 路
Hi again , here's the list of components in my 1916
Engle W110 cam
i beam rods with ARP bolts
94mm piston and cylinders
8 dowelled crank
Scat lifters
Empi solid rocker kit
SS pushrods Empi head stud kit
Scat swivel feet adjusters
Empi Heads ported and polished
Empi 40mm downdraft carbs
8.3:1 comp
kennedy clutch kit
86hp@5800
1916baja 路
ValveSize? Headwork?
Bizarre 路
I would be VERY happy with 86 ponies with that set up
Well done
vw54 路
The HP figures always depend on which dyno your on
As per above the figure is only a guide and next time you make a change, go back to the same roller and operator to compare your figures
Dont use any other machine or operator
that HP in a buggy will get you anywhere reasonably quick
waltermitty 路
macdaddy67350 wrote:Hi guys just had a 1916 built and was wondering if any one else out there would know what sort of horsepower i might expect from it . IT made 86 hp at the tyres yesterday , was hoping for about 100 but maybe i was expecting too much, any help would be appreciated , thanks
Well 86 @ the wheels aint bad as said . And very close to the 100 you were after at the crankshaft. Mitchell
Ollie 路
That seems like awesome power for that set up mate! I'm surprised it made that to be honest! Where did you get it dyno tested?
Would be a blast to drive 馃檪
macdaddy67350 wrote:Hi again , here's the list of components in my 1916
Engle W110 cam
8 dowelled crank
Scat lifters
8.3:1 comp
kennedy clutch kit
86hp@5800
macdaddy67350 路
Had it dyno'd at Jakes Performance in Canberrra, going to race it at wakefield park on saturday 21st May at the VW supersprints, anyone else going to the sprints or to the nationals at Fairfield?
macdaddy67350 路
Anyone know how to add an avatar to my profile ?
Bizarre 路
macdaddy67350 wrote:, anyone else going to the sprints or to the nationals at Fairfield?
Almost everyone (except me 馃ゲ)
Pretty sure the V Force boys are going beetle racing
13bwagon 路
macdaddy67350 wrote:Anyone know how to add an avatar to my profile ?
yes sure do i made my avatar an avatar 馃槀
rose 路
I'm going racing in Ian's 70 bug can't wait and Andrew in his buggy from newy
I'd be happy with that hp
My best time out of a 1916 on 1/8th mile was a 9.66sec my oval only weighs 687kg and around 65hp
poor bazza馃槩
vlad01 路
Joel wrote:Is this for street or strip?
yeah but V8's are slow and heavy. I even flog most V8's up to VT versing me in my V6 VP.
few minor mods the relatively stock engine puts out now around 190-200hp in the one of the lightest commy of all at only 1250Kg. 0-100 in 6.5~ sec. 馃お used to do 0-100 in 12sec. Don't know what happen there 馃檯 oh only a near complete rebuilt of the car and it still looks like a POS with all the paint looking like used sand paper馃槀 It what inside that counts and P/W ratio make a difference.
Most cars are 1700Kg now. ffs a 2001 Hyundai accent weighs more than my commy 馃檯 sad but true
Joel 路
vlad01 wrote:yeah but V8's are slow and heavy. I even flog most V8's up to VT versing me in my V6 VP.
That's old news, we already know thanks to boostcruising that Buick V6 commodores are the fastest thing on 4 wheels.
It's funny how newer cars are still getting heavier even though the metal quality is going down the shit shoot.
My old man is looking at a Peugeot RCZ which has a turbo 1.6L but is 1400Kg, I was expecting a pretty slow time but surprinsgly 7.5secs.
vlad01 路
I am thinking of getting a nice VR preferably a acclaim or berlina as they typically had IRS.
Then waving some of my magic over it. There is plenty of weight reduction to be done on these commys.
Most of the weight reduction is done via drive-train and exhaust. oh and AC, who needs AC? 馃槀 also changing to a cheaper aluminum radiator
looses around 4-5kg and even though the Al rads don't transfer heat as good and to make matters worse are thinner too, but out of experience these is no real notable loss in cooling. The V6's don't produce much heat for their size. It's when engine heat output exceeds radiator heat dissipation then you have problems.
I think the VR was the best commy ever made as is had much improved body design, the dash was made from a much better plastic and looked better, it was the last gen of the buick with a whopping 9:1 CR and sequential injection, IRS was more common, the paint was somewhat better than the VN-VP and heaps better than the VS-VT馃槀
best part of all the VR was only about 50~kg more than the VP. its from the VS they started to get heavy.
The thing that makes me like commys (mainly from VL-VR) is they are not really aussie cars. Mix of opel, buick and in the case of the manual versions also some mustang mixed in there. I bought Mustang parts from the US for my VP as the were NA here.
I am in Switzerland right now and there is tons of commys I mean opel 馃お same models and names as the commy in oz lol just some small differences.
Craig Torrens 路
^^ maybe move this crap to the holden forum ! 馃槈
vlad01 路
yeah I been there once I quit after a few weeks because they are very stupid cock heads. argent ass holes too.
HURRR DUURRR DERP! my car is surging, I have already changed the plugs? what do I do now?
Response: DERP! ERRR! have you check the tyre pressure? mmm HURR time to take it to the mechanic.
