Had a play around with my wheels the other day just trying to get a picture of backspacing, centre hole, etc to see what my options are in regards to wheel fitiment on my bug.
Looks like a small positive offset and an ability to re-drill drums and disks to basically whatever PCD I want (Assuming I have blanks, which look easy to come by).
Only issue I see is with the fronts, the centre hole (where your stub axle comes through the centre of the rotor) is 81mm, that is massive, if you are going to a 5x114.5 PCD that would leave f-all meat on the rim between the stud holes and the centre hole.
So was wondering........
Anyone running a 5x114.5 PCD (or 4 x 114.5 PCD)?
Anyone running non-standard hubs with a smaller outter bearing so you have a smaller centre hole - I am assuming it is because the outter bearing is rather large that contributes to such a wide centre opening in the rotor?
Anyone running custom hubs?
I have wide guards and a set of 17x8's lying around - Fitting them on the rears seems straight forward enough, with re-drilling a set of blank drums or even just re-drilling a re-using 1 hole.
BUT............the only way I can see that you can do the front is by running a set of custom hubs with a small centre opening in order to run this smaller PCD?
aussie260z ·
