bottom front shock mount
https://forums.aussieveedubbers.com/threads/90337/bottom-front-shock-mount
bugzla ·
hey guys
any body had the problem that there is just not enough thread on the bottom shock stud to put a nut onto when the bracket for the selby sway is placed on i can get a nut but no washer, was thinking of extending it has any body done this or is there another way maybe locktite
vwo60 ·
The correct ISO standard is three threads past the nut, you should also use the washer provided, i recommend you go to the local bolt place and purchase a pair of the correct length grade 8.8 bolts.
bugzla ·
this is for the front not the back sorry
bugzla wrote:hey guys
any body had the problem that there is just not enough thread on the bottom shock bolt to put a nut onto when the bracket for the selby sway is placed on i can get a nut but no washer, was thinking of extending it has any body done this or is there another way maybe locktite
I'm guessing its a ball joint torsion bar front end...??
and it fits onto a stud... not a bolt...
Problem...
You can't replace it...
leave the washer off and loctite it on...
pete wood ·
Is there a way of narrowing the bottom bush for the shock? I'd look at that. I know the issue you are having too. Try asking the qu on the circuit racing forum. They are all running the same sort of stuff you are.
I remember grinding the bushing a few mms both sides with some shocks that had very wide bushes..
they are just only long enough those studs...
I can't see any way of lengthening them...??
