Aussieveedubbers 路 Non-VW Engine Conversions
twin scroll for kombi torque
https://forums.aussieveedubbers.com/threads/90422/twin-scroll-for-kombi-torque
rocknrob 路
Well some time ago i aqquired a twin scroll VF38 to replace the TD04 i had been running on an EJ22 in my kombi. I had read good things about its early torque production which is very useful in a kombi used for puttering along dirt roads in second with big hills ahead...
at the time i mentioned it i had some hilarious responses(http://forums.aussieveedubbers.com/viewtopic.php?tid=81700) but finally found some time to do something about it.
being twinscroll my homemade manifold needed reworking...this is what ihad before:
[/img]
so into the 14" cutter
[/img]
last time i used gal waterpipe but went upmarket this time and bought a length of fire sprinkler pipe from the recycle for ten bucks....36mm ID...perfect...many many cuts on the saw...neighbours would hate me except Ian used to have a kombi...
anyway....
[/img]
and...
[/img]
[/img]
[/img]
test fit was good so time to weld it all up
have to adjust the dump pipe a little and a few other things
then it will be time to see....boost from 1600rpm?
rocknrob 路
geez just noticed the surface rust on the rotors of the bikes...better go for a blast and get rid of that馃槀
Joel 路
I'll be interested to see what you think of it.
Is it going on the 20 or the 22?
I've got a VF23 there but my subi guru tells me a TD04 would be a good choice for the 22.
rocknrob 路
Joel in your case yes i think the TD04 would be perfect...lighter weight and only road use...the kombi was a weapon on the highway with the TD04 but i'm looking for lowdown grunt...at present i'm running the EJ20T but the plans are for the EJ235...just playing馃槑
rocknrob 路
Also have a TD04 surplus to requirements going cheap....
mackaymanx 路
Wow, I have that same compak welder sitting in the garage. Just keeps going.
Craig Torrens 路
i like the mandrel bends 馃榾
rocknrob 路
heheh yeah its gotta be ...oh no...40 years old...gulp馃檯
Vw nutter 路
jesus!!!!
i like the 14" cutter and the chinese safety boots 馃槈
be interesting to see how it runs....
rocknrob 路
not quite running yet but it looks like it should be swimming in loch ness instead馃槀
just finishing off the dump pipe and intake as they are different to the TD04
[/img]
seagull 路
Rob, for you having a dam good go at this with simple tools & a bloody stick welder.
I have a water to air inter-cooler from a Toyota here for you Free , you will need the water pump & the radiator for it
seagull
rocknrob 路
Hey thats fantastic Neil...i got it going and it went great but the bloody turbo needs a rebuild馃槵 but i'll get a kit for it...i'll take you up on that cooler will send details but just heading out the door right now to go camping...brrrr...forecast 5 degrees but sunny...good thing i'm taking a bedwarmer....heheh馃槒
