Was wondering if anyone could help me out with measurements of the stock from Front Beam with Ball-Joints.
Just not 100% certain mine is a stock width because it looks like someone has installed Sway-A-Way type height adjusters into the top and bottom Front Beam...............so they might have also shortened it up a touch!
I took a measurement (See below)
And was wondering if this is the stock width???
(This is not mine, just used for illustrative purposes.)
I came across information that said the stock Front Beam is 34 3/16" - Which works out to be pretty much 75mm wider than mine, but not sure if this is correct.
Anyone know what the stock width of the Ball-Joint Front Beam is?
Don't want to order the wrong Sway-Bar :-)!
aussie260z ·
