VintageSpeed Exhausts Bolt Straight on
https://forums.aussieveedubbers.com/threads/90461/vintagespeed-exhausts-bolt-straight-on
Governor ·
One of the first Vintagespeed exhaust's that we know of in the country was fitted to a 2007cc in a split kombi over 2 years ago, this produced over 97 BHP at the wheels and was still making power at 175 KMH on the Dyno (at Leons Motors)
The Last 5 Motors B4 has built all use Vintage Speed Systems because they have proved that they bolt straight on, no modifying any bodywork or manipulation to the system to make them fit.
Merged Super Flow good for up to 2.3 Litres
The quality of the fit & finish is second to none
as seen in the photo's
Governor ·
1600 Bay Kombi with heater Box
as seen in photo
Governor ·
Beetle 2 litre without Heaters 42 mm Pipe diameter
The fit & Sound is Fantastic also photo attached
Vintage Vee Dub Supplies in Sydney are the National Distributor,
Boris 02- 9789-1777 .
Dave Pryor in S A is also available to Build Quality Air Cooled Engines using Vintage Speed Systems.
B4 Performa Engines 0402-096-797
Thanks for Looking
vwo60 ·
I bought mine direct from the factory in Tiawan for about $ 450 delivered.
STIDUB ·
is this just sharing info with the people or is it supposed to be an ad without sponsorship?
seems more the latter but either way looks good.
SuperOwen ·
I have the 1.9 SF muffler on mine, sounds great although I havent had the chance to drive it far yet. The fit was PERFECT!! Very pleased with the quality and vintagespeed were happy to make the header to accomodate a filterpump style setup with only a minor delay.
Would definatly deal with vintagespeed again.
waveman1500 ·
Wow, that merged Super Flow is an interesting design. What are they like in terms of access to the nuts? I just installed a sidewinder exhaust on my Superbug and couldn't get a socket or ring spanner on anywhere due to the diameter of the pipes, had to use open-enders.
waveman1500 wrote:had to use open-enders.
or smaller nuts, 11mm spanner, M8 x 1.25 threaded nuts available. I have plenty in stock if you want them....good for inlet manifolds too.
Very nice exhausts and B4's work is awesome as ever 👍
Great looking exhaust.................how do they adjust for different width motors ?
made to suit diffferent types
lots of thought put into these
Governor ·
Craig Torrens wrote:Great looking exhaust.................how do they adjust for different width motors ?
The merged superflow can be adjusted width wise by using the Vintagespeed spacers between where the pipes attach to the actual muffler
Gracey ·
What can you tell us about the merged super flow exhaust on the black bug?
Have you done any dyno testing?
How does it compare to a typical merged exhaust - performance wise?
Governor ·
As mentioned the quality is amazing, it bolted straight one, no mods to bodywork ect.
I believe he had a Berg 1 7/8 merged exhaust on it and prefers this one.
No Dyno testing but the owner says he can tell the differance and believe me B4 knows.
Thats why he will recommend these exhausts over everything else
If you google Vintagespeed, go onto their site and they have loads of videos of their exhausts on the dyno and compare them to others as well
BeetleJuice ·
I believe Lukey made exhausts similar to these for 4cyl Porsche and VW some 25yrs ago??
I do like the look! 😎
Would like to know what the internal baffle system looks like!
Gracey ·
Thanks Black64, I've been looking at the merged super flow exhaust for a while and trying to find some real life experience and testing on it.
However there doesn't seem to be much on the net.
http://www.store.vintagespeed.com.tw/ Unfortunately there's no dyno testing on this exhaust.
That was about 45 plus years ago
they made for the 1200 engine
I have several origionals they work great
These are staino and you wont have to replace them
Paulc1964au ·
Are these equivalent in performance to sidewinder exhausts
Newt ·
Scuise my ignorance. Is that an oil cooler hanging under the black bug?
Newt
Governor ·
No its an O'Berg oil filter
