WTD - QLD 6V Battery
https://forums.aussieveedubbers.com/threads/90515/wtd-qld-6v-battery
willtrack ·
Hi guys,
Im in need of a 6V Battery with a little bit of life yet. I just need it to crank a 1200 Beetle engine.
Contact: Wayne
Ph: 0416103490
Cheers.
grumble ·
Try Battery World they have 6v batteries,I purchased a deep cycle one for my Ghia. Good used 6v batteries to the best of my knowledge don't exist.
willtrack ·
I just need one to try this engine to see if its any good. All my other engines are all 12V, so dont want to buy a new one just to start this thing once.
LUFTMEISTER ·
just use the 12v battery on the starter.
NUG637 ·
ive got one that was pretty new when i did the 12v conversion on the 61, been sitting for a month or 2 now but should still hold charge?
bushed ·
am i right u need a 12 volt coil for it to purr on a 12 v battery
?cheers
LUFTMEISTER wrote:just use the 12v battery on the starter.
ian.mezz ·
just jump it with a 12volt.
greedy53 ·
dont need to change anything if you only want to start it 12 volt on 6 will start it if you wan to drive it well a 6 needed if you want to try a few retailers you can get a 9 volt from forklifts
bajachris88 ·
If you modded a 12 volt battery to have a terminal in the middle between the 3rd and 4th cell, Use that as your positive terminal, and the original two as both earths, would that be the equivalent of a dual 6 volt battery setup?
