VW Nationals Supersprint Results
https://forums.aussieveedubbers.com/threads/90556/vw-nationals-supersprint-results
amazeer 路
http://www.natsoft.com.au/cgi-bin/results.cgi?21/05/2011.WAKE
You should only use this to look at your own times as some classes may need adjusting.
Unfortunately there were a few mechanically injured vehicles this year, more than I recall from previous years. And even a few that happened before racing started. 馃檨
amazeer 路
dammit. think I might have left my printer power cable at Wakefield. Can someone please print these and take them to the show for me tomorrow? If you know/see me you you can give me direct else take to merchandise stand. Much appreciated.
Camo 路
Printed. See Kevin (me) on the main gate entrance, I will (should) be working there with Dave Birchall.
Kev
Craig Torrens 路
With Birchall.......isn't he the slug driver that had his arse KICKED by Rose ??馃槀馃槀
dangerous 路
Thanks for the results list.
So which class had the fastest air cooled?(not vees)
Hard to tell what has water cooled engines out back these days.
Brian 路
Troy was the quickest non turbo bug
Brian 路
Rudy had the Quickest air cooled bug by far
but that Wing is uglier than Princess Beatrice 's head piece 馃槀
Craig S 路
Brian wrote:Troy was the quickest non turbo bug
Is that number 131??
What sort of engine spec is in that?? I didn't really notice that it was particularly quick, but the times show that it was. Obviously going about its work without too much fuss.
vw54 路
Tugger
at least i was there no like some talkers
sander288 路
I think I was the only one in my class... no one else would be silly enough to take a stock 1300 out
Default Win!! 馃槀
Craig S 路
sander288 wrote:I think I was the only one in my class... no one else would be silly enough to take a stock 1300 out
Default Win!! 馃槀
You might not have been going at the speed that Rudi was going, but your car looked much more composed than it did last year.
Last year it was a but wobbly through corners and had the terrible swing axle habit of trying to go up on the edge of the tyres, but this year it was going much flatter through the corners.
Although I did hear one person wonder out loud whether you had to brake for corners or could just fang it through at full tilt!
dangerous 路
After Rudi, it looks like Troy Traeger #131(1915 efi?) got the qickest normally aspirated Volksy, followed by Nathan Hearn #74(type 4?), then Greg Mackie (2lt?) and Rod Penrose(2276), then George Gershos.
sander288 路
Default Win!! 馃槀
I can thank Greg Mackie for the help; he has built me a pretty sweet camber compensator to tame the swng axle somewhat.
And yes I pretty much was full tilt the whole way around; I only braked slightly at the end of the straight becasue If I slowed to much i'd never get the momentum back to get up the hill!! 馃槀
vw54 路
4th in class good 馃ゲ
Bizarre 路
Yeah - Nathan is a 2.7L type 4 IDA motor in a fairly well sorted 1303
He is fairly new to all this and reckon it is a pretty respectlable effort
