Aussieveedubbers · Bugs
Clutch pedal has dropped forward
https://forums.aussieveedubbers.com/threads/90600/clutch-pedal-has-dropped-forward
Gurujimmy ·
Hi guys this is my very first post, My clutch pedal has dropped forward towards the drivers seat, does anyone know the cause and or the cure for this.
Still drives fine i just have to leave my foot on the pedal so it easy to depress.
hellbugged ·
there is an adjustment plate under the brake and clutch pedals that will hold them at an even and correct height
it may need adjusting or the tang on the end may have worn down or broken
Gurujimmy ·
Thanks mate I will check it out🙄
hellbugged ·
hard to see, but there is a square tang right on the bottom of the pedals that rests against the adjustment plate......i'm looking for some pics
what year model the 64?
two 13mm head bolts that go into the floor behind the pedal set, plate under there so loosen them to move the plate around. (use some WD40 etc of your choice) don't let them fall right back when you loosen the bolts.......clutch cable may fall off hook in tunnel then 🙅
Gurujimmy ·
64' deluxe
