I know you're saying "Huh?", and wondering why someone with an EA81 could possibly want one. Well, it's like this;
I discovered that the cruise control in our dead Magna is pretty much an independent system and it looks like it may also support manual transmissions. besides switches etc. to monitor the pedals and three control buttons, all it really needs is a VSS.
The Mitsubishi VSS seems to supply 4 pulses per revolution. Even though the VW runs larger wheels I know I could get away with something compatible if it were just cruise.
I would be more than happy with more pulses per revolution as I'm pretty sure I could make a conversion box without too much hassle which would let me calibrate based on wheel circumference too.
What was I getting at? Oh yeah. I discovered that the much sought after digital gauge cluster from out 1st gen Magna fits in the VW gauge cluster hole nicely with space on the side for the cold air lever. Besides needing a whole pile of blade connectors, the cluster seems pretty compatible as its signals are raw. Even the tach is a coil feed. The only difference is the electronic speedo.
My thinking is this would be a fiddly but easy install and would allow me to eliminate all the gauges sticking out from holders around the place.
So far I'm only speculating, but so far the only issue I can see is with the speedometer needing a pulse.
I know the photo is in my thread but here it is for reference.
So it hasnt got an ordinary speedo cable input on the back?
nearly all the 80s digital LCD clusters like the elante/elite magnas, subi vortex, toyota soarer etc used a normal speedo cable and the VSS was inside the cluster.
Easiest solution would be a proximity sensor and a wheel of death like I've got, you just need to find out if it needs an NPN or a PNP signal but nearly all back then were NPN.
Ben386 ·
Mr Failure,
Im am not familiar with your engine,but this cable driven vss may interest you. http://www.rjes.com/html/vss.html
I did think that pre ej25 98-01 did not require a vss.
I am using the second one that mounts to the back of a T3/T25 speedo.
All good, no fault codes or engine light.
General_Failure ·
Joel: No speedo input. just VSS. The digital cluster got its signal from the tranny. The analog had a cable and a reed switch for cruise.
Ah... do you mean like low-high-low as opposed to high-low-high? Just asking because NPN and PNP are different substrate arrangements in a transistor which could also be valid.
Thanks for the link Ben386. That info is solid gold with the speedo cable fitting. My engine is something very simple and not far removed from an ACVW engine. The VSS isn't remotely necessary as-is. But I do have this nice cruise control system just sitting there and a set of instruments which by sheer coincidence will fit pretty easily into the dash. I'm at a halt with the resurrection right now anyway because I'm out of $ and resources so a bit of a side project seemed interesting.
Another question. I know ages back an instrumentation swap didn't require engineering as long as the new speedo had an odometer. is that still the case?
General_Failure ·
I can't find anything on needing certification to shove this cluster in. Am I missing something? Still not sure I want to do it, but it is a "bolt on" mod of sorts. No alteration to the original vehicle is necessary. Well, almost none. I figure I might have to move the (non functional) knee vent / top vent control. I'd probably do that with a choke cable kit and put it in line with the other knobs, and put a lit toggle or pushbutton next to it labelled "Heat" which will drive the heater fan. Too hot (as if that could happen) open the front flap.
I like Joel's Wheel of Death" idea. I just hope the digital cluster doesn't need signal conditioning. I like the neatness of the VSS too. I don't know.
Does anyone see issue with me lopping off the magna gauge harnesses a half meter or so away from the connectors? I don't think I'd regret it because all the original VW connectors are blades anyway so I'd have no long cable runs.
What I might do next is photograph and label all the wires on the back of my VW cluster (a lot of additions imagine that!), unplug everything and ensure the Magna cluster does drop in. I tried flopping the cluster out yesterday but the wires are too short to get it out of the way. my steering wheel doesn't help either.
Ben386 wrote:I did think that pre ej25 98-01 did not require a vss.
Every EJ engine thats fuel injected needs a VSS.
That's so the the computer can work out mixtures on over run mainly, some will run ok and not stall without one but they will all benefit from having one.
Mines got 1992 engine management and almost used to stall at stops and constanly threw IACV error code when coasting when my VSS stopped working.
many others have also experienced this.
Can even lead to limp mode/rev limiting on OBDII stuff.
General_Failure wrote:Joel: No speedo input. just VSS. The digital cluster got its signal from the tranny. The analog had a cable and a reed switch for cruise.
You're right, in thinking back to the TP Magna Elite Pop bought new in 89 it had a digital odometer.
WHen that digital LCD speedo craze happened in the 80s most still had old analogue rotary odometers which was why they had a cable still.
With the NPN vs PNP its negative pulse and positive pulse.
Nearly all your 80s and most 90s cars just used a negative square wave pulse but toward the late 90s many manufacturers inclusing Subaru went to PNP 5volt speed sensors.
ttriebler ·
Stop mucking around and just put a reversed Subie box in. They already have the VSS !!!!!!!!!! 😂
General_Failure ·
I'll check the manual to be safe, because the testing procedures for the VSS' are a real tell. But I'm 95% sure that they are NPN.
ttriebler, I would love to. Unfortunately the mucking about and cost required for that would be unbelievable. Putting cost aside, The EA81 would be pretty useless at pushing a bay with longer gearing around. Then it would need an adapter plate of some description anyway because my EA81 has one of those Sherman engine bellhousing replacements that have the VW stud pattern. Would certification be needed for a subie transmission? Once again, cost aside a huge nightmare. The closest engineer is interstate and 300 odd km away. the nearest NSW one is about 350km away so there is getting there and back too.
If no certification is needed and the EA81 would be okay with the subie box and I had an adapter and I could summon up the required $, yeah absolutely I'd love to! 5 gears would be awesome.
ttriebler ·
I was just joshing. I'm sure your setup is fine.
But you know an EA transmission case is identical to an EJ transmission case right? Except it has the EA bolt pattern. All the EJ goodies fit into the EA case. So no adaptor plate needed.
General_Failure ·
ttriebler wrote:I was just joshing. I'm sure your setup is fine.
I didn't know that. Very, very interesting. Hm, maybe I should start collecting parts. The challenge would be to find someone with a trashed EA81 that I could acquire the engine bellhousing from, because like I said mine has been replaced with a VW pattern one.
ttriebler ·
Your EA81 engine doesn't neeed a bellhousing. You unbolt the VW adapter plate and then bolt the EA81 engine straight up to an EA transmission.
General_Failure ·
ttriebler wrote:Your EA81 engine doesn't neeed a bellhousing. You unbolt the VW adapter plate and then bolt the EA81 engine straight up to an EA transmission.
Look on here. Their captions are a bit screwed up. Some above, some below the picture. Look at the one below the caption that says "SUBARU - 1400, 1600, EA71 1800, EA81 1800, EA82 O.H.C".
See how there are inner bolt holes. Those replace the engine bellhousing, for lack of a better term. The thing that mates the engine case to the transmission bellhousing. The other motors have adapters. this one is a replacement. So you see I would need an original Subaru version of that as I only have the VW drilled version. Of course I'd need a flywheel and starter too.
edit: I should add, that is the same as my thing. A Sherman one.
ttriebler ·
Yep gotcha. I didn't think that they would have removed the ea bellhousing and made a new bellhousing to suit vw. Thought it would be an adapter plate fitted up like on the EJ's. The EJ's are part of the block. Anyways.....back to the VSS.....😂
General_Failure ·
ttriebler wrote:Yep gotcha. I didn't think that they would have removed the ea bellhousing and made a new bellhousing to suit vw. Thought it would be an adapter plate fitted up like on the EJ's. The EJ's are part of the block. Anyways.....back to the VSS.....😂
No worries. my research fee is one R&P 😂
I'm still trying to penetrate that vault of a dash on the Magna to get to the cruise control control unit. It's unbelievable. Packed solid behind there. The only issue I thought of with the Magna cluster was maybe the fuel gauge. The truck one I'm using currently isn't right any more anyway since I tried changing the light bulb I'm using for current limiting to a smaller one.
Further back to topic. I saw a box on Dakota Digital's web side that converts VSS inputs to a form usable by different gauges. Because I'm cheap / broke I figure making something like that myself would be the way to go. Hopefully I still have some smaller microcontrollers stockpiled. If not I guess I'll have to get one. the real issue is how I should go about getting the signal. A proper VSS of some sort, wheel of death or similar (I like that name. thanks Joel) using hall / optic / various other methods like a reed switch. The crazy in me would like to do something like a notched disc or daisy wheel of magnets on an inner CV / axle and use a quadrature decoder to get a high res signal to work with but I don't know if it would be worth it.
Any pictures of your setup Joel?
ElusiveStranger ·
GF there's a nice thread on here about VSS. Brantz do a nice one.
Ask EJ71Van if he's happy with his. Vauxhall/GM gearbox one fits the back of a Type 1 or Type 2 speedo - 4 pulses per wheel rev @ 5V (same on a bus as a Leggy ±5% IIRC)
Here ya go, just a $25 NPN proximity sensor and some scrap metal.
Will hit 14,000kms some time this week, never given me a problem and it's seen plenty of nasty weather but its supposedly water proof anyway.
With the frequency it can handle it's supposedly good for over 300mph.
I've had it to blinker light on a 160km/h speedo anyway.
General_Failure ·
Holy crap that thing is terrifying!
I'm thinking something like just getting a cheap pack of rare earth magnets, putting them round some part of the rotating assembly, maybe the bit that the CV bolts to on the transmission and using a reed switch or a hall switch (not just the sensor).When I get a few minutes I'm going to punch the tyre diameters of the van and the magna into a tyre calculator and see the circumference difference. If I'm lucky the VW has about 20% larger circumference. Why? Well I could put 5 magnets on instead of 4 and have the speed more or less right.
I also had another look at the Magna cluster diagram this morning. Bit off topic but it looks like it has a built in 7v regulated supply for the fuel sender. it's close enough to what the mean of what the VW vibrator outputs. I'm so tempted to go out there and hack the harness off as is and start wiring on relevant blade connectors. The 'cruiser heater is ready to be picked up at the post office soon I think so I have a real project item again, sort of. Besides testing it I can't do squat without piping besides plumb it in and sit it above the engine bay to make sure it works. Might be hard to believe but my bay's engine bay is starting to get cramped.
😂 Hence it's name.
There are far more elegant ways to do it, in the front hub sensing the wheel bolts for example would be a neat way.
I just went for the easy solution and I also wanted it on the rear driving wheels so it didn't spack out on dynos when the front wheels aren't turning.
I did actually try the magnets and reed switch deal, worked briefly then failed miserably.
another subi conversion guy I know tried it too but using the subaru reed switch, same deal worked for a bit then stopped.
General_Failure ·
Joel wrote:😂 Hence it's name.
Ahahaha. I think I know why that failed after a bit. Possibly magnetic flux in the CV, but I think the most likely thing is that all those big spinning magnets magnetised the angle iron bracket the reed switch is mounted on.
Ben386 ·
Nice work and photos Joel.Wheel of Death.I like it.Needs some red painted on it.😂
General_Failure wrote:Ahahaha. I think I know why that failed after a bit. Possibly magnetic flux in the CV, but I think the most likely thing is that all those big spinning magnets magnetised the angle iron bracket the reed switch is mounted on.
It was just the reed switch was good enough for the job, which wasnt surprising it was $5 home alarm door switch.
Worked fine at low speeds just couldnt handle more than 90km/h
General_Failure ·
who needs to go above 70 anyway, hey?
General_Failure ·
I ran the tyre numbers on the calculator today and found out the curcumference difference between magna and VW is 5.38%. IIRC the magna has rubber slightly too small on it. I'll have to check its book. If so a standard 4 pulse sensor will do. I reckon it'll do anyway. Close enough.
I pulled the VSS out of the Magna. Gregory's instructions had me pulling it out, shaft and all. It's just like a messed up distributor. The VSS just unscrewed off the top of it. Anyway the Magna VSS has a female screw thread and a male round shaft with a tab on it. Can I use this somehow, or is it in the too hard basket?
General_Failure ·
Joel, you got me thinking. I remember years back extracting the reed switches from reed relays. The long ones with the external coil. They'd probably be a much higher switching rate. I'm going to have a bit of a look at what's out there.
General_Failure ·
Going for an addition here. I found proximity sensors that look like Joels. However they need magnets. Are there magnets on the back of the wheel of death, or is something else going on there?
General_Failure ·
I just ordered a proximity sensor and some neodymium magnets. They should be here in under three weeks... probably. I know this all seems like an exercise in futility. maybe it is, but I like to experiment.
General_Failure wrote:Going for an addition here. I found proximity sensors that look like Joels. However they need magnets. Are there magnets on the back of the wheel of death, or is something else going on there?
Mines inductive so it only needs metal to trigger, same deal as at the airports.
The one you have found is a magnetic version, which will work fine, you just need to make sure the magnets stay put.
Biggest killer of aftermarket cruise control kits is the magnets entering orbit when the epoxy lets go.
General_Failure ·
Ah that explains it. I'm happier with the type I got anyway. Inductive is awesome to be sure, but I felt a little uncomfortable about a notched wheel like yours. Wouldn't surprise me if the magnets emancipate themselves eventually but it's no big deal. Anyway I got small neodymium magnets for a reason. lots of magnetism and low mass. I'd probably secure them with JB Weld or something to be safe.
I'm out a little over $12 for the lot, so it's all good 🙂
This morning I was tracing wires on the Magna schematics. Got it all figured except the mysterious "Lamp control unit" on the digital cluster wiring. The analog has rheostat.
Interesting thing is the schematic shows both sides of the backlighting circuit wired to a positive feed on different circuits. Really confusing especially because it shows the bulbs wired directly to each. Multimeter time I guess.
Big stupidhead me realised I can easily work out what I need for neat cluster fitment without pulling the gauges out. The glovebox hole is the same size as the cluster hole. Only difference is the lack of screw holes.
General_Failure ·
I just did a rough test fit on the drivers side. it would be fine except for the pivot that the heater control levers are on. Damnit. There are options. Either cut mine, find another or just make my own single bracket, which would probably be the easiest.
No matter what I'll make up what I need to patch it in to the electric and see if I can make it dance before anything is done.
General_Failure ·
I managed to power up the digital cluster today. Partially anyway. Both standby and running. The backlighting still has me stumped. Both inputs to the bulbs according to the manual are positives from different circuits and then there's a third mystery wire which may control things. It's a little unclear though. Unlike standard gauges these have to be lit whenever the ignition is on, and I think the brightness changes when the headlights are turned on.
General_Failure wrote:I think the brightness changes when the headlights are turned on.
You got it.
The LCD display dims when you turn the parkers on so it's not as glarey at night
General_Failure ·
Trouble is I don't really remember it too well any more in its original application. The backlight wiring is still a bit mysterious though. I'll have to empirically test the states of the backlight wires and the mysterious third wire.
General_Failure ·
The magnets arrived a week or two ago. The proximity sensor finally arrived yesterday so I can get back to it. Thought I'd say it hasn't been abandoned. Just slow postage.
vlad01 ·
hahaha you used a read switch you dufus 😂
I am surprised it even worked above 30km/h. That would be a good one to post to "thereifixedit.com" . You must admit, its a good one to use an alarm read switch and some glued on magnets. 🤓
Plenty of hall effect sensors out there in all different shapes and sizes.
ETB instruments are great to deal with, good quality stuff.
What you think stock was?
omg a reed switch....🙄
Worked fine upto about 100km/h.
Others have been using the same setup for years, for $9 i was happy to try it.
Proximity sensor has been working fine for nearly 17,000kms now
vlad01 ·
stock? um a speedo cable lol
yep proxi sensors work on hall effect most of the time some use induction coil i think? they are a good choice.
you can also use photo interrupter sensors but need to a type that is resistant to dirt and water.
Stock Subaru.
Using an inductive prox setup now.
I've only had it to 180km/h so far but in theory its good for 300mph 😂
vlad01 ·
180? how is the aero of a bug at that speed?
I would not wanna do those kinda speeds in a stock car with it's nose in the air, you would take flight but a lowered Lbug with big shoes is very firmly planted at those speeds feels like it's sitting still.
Even the vids on youtube of Wallys turbo type4 Lbug doing 220km/h on the autobahn looks like driving Miss Daisy.
vlad01 ·
hmmm? thats rather interesting. Well there you go, a bug is more aerodynamic than people give it credit for.
I also know the type 3 is very stable at speed. I have managed to push a late squareback down a massive 800m long 20o decline and got it to 150Km/h
was a pretty stable, wobbled a little on those summer days with strong cross winds.
VW's are alot more stable at speed than people give them credit for.
It's only when they have rooted shocks, flogged out bushings and tyre pressures all over the place that they get hairy.
You only have to look at how well they do on the track to see how well they can handle with some work.
Even a kombi can hang on well, watching Steve Muller I think it was flog around the Raleigh track in the splitty camper was pretty impressive a few years back.
General_Failure ·
I've put this project on the back burner for a while. I have everything I need but it's in my best interest to get it roadworthy by end of year-ish. To make the cluster fit I'd have to fab a new heater lever setup because the OE one interferes. besides that the cluster is the right shape and size, with a small gap to have the vent flap lever going through still. Problem is I want to drill some gauge holes between the ashtray and stereo. Why is that a problem? Well because the cluster I have would obsolete all those gauges. I suppose in the mean time I could fab a multi gauge bracket instead of all the warts all over the dash it has now. Hole saw, the 2.?mm steel I've got and a bit of grinding and welding. All good hahaha.
Now I think of it the LED bulbs I have on the way are the same type the Magna cluster uses. Hmmm. Honestly I don't want to give the inspector any extra ammo. I know that I can do it legally and all, but blue slip with a 36 year old bay which while in good physical condition looks like it was in a battlezone, and with drivetrain work that is on a razors edge of needing engineering, best to play it safe until then.
If I can figure out how the hell the backlighting circuit in the cluster works I'll be well ahead. I think I said it before but what is in the wiring diagram just plain doesn't make sense for the digital cluster. The analog cluster is fine though. They both seem to use an entirely different method of controlling the light.
