12v Flywheel - 6v Gearboox?
https://forums.aussieveedubbers.com/threads/90736/12v-flywheel-6v-gearboox
stifler001 ·
Hi guys,
I was wondering if you can fit a 12v flywheel in a 6v gearbox on a 66 beetle? (if that makes sense)
silver ·
yep with a bit of clearancing of the 6v bell housing it will fit ok
stifler001 ·
Cheers!
psimitar ·
you'll need a 12v starter too as the pinion gear has different number of teeth.
VolksVair ·
12V starter motor bush
u need a adaptor bush for the starter as the OD on 12 and 6 bushes are different
U need a 6V od and a 12V id bush which are available
