Andy wrote:Hi all,
Might finally give up on points for the bus unless I can find some one selling Beru points still?
Anyway, I have an unused Compufire unit to fit the stock dizzy. The instrsuctions seem straight forward.
Any tricks/tips when installing?
Do you need to check the hight between the pick unit and disc, and also if the rotor is at the right height after installing?
Do you need to change the rotor/coil also, or are stock units fine?
I thought Beru plugs etc would still be available although many are selling BOSCH or copies...
I'm not sure with the compufire , but with Pertronix , the Coil needs to be 3 ohms resistance or more...
most coils are 1 , 1.5, 2, 2.5 or 3 ohms...
I bought a few looking for the correct resistance...
I don't think its critical where the top of the magnetic piece is
but closer the better... once you push the rotor button down onto the shaft.. that is where the top of the magnetic piece will be..
My Son just installed a kit in His car, can't remember what brand it was... will have to ask Him... as He wouldn't have checked the resistance of the coil...
You can use a ceramic resistor as used in old Fords and Commodores etc... to add to the resistance...
Points are OK if You can find them with the bakelite rubbing piece as the plastic etc wears out too fast..
I was running an electronic high energy ignition system with points and the rubbing piece was white plastic or nylon which kept wearing down and then turned and shorted out My high energy ignition system... lol
