Hi Guys,
I seem to have a fairly strong fuel smell in the car that I can't get rid of. So far I've done;
-Fuel Cap - replace with aftermarket. Useless. Replaced with genuine german one.
-Filler Pipe - visual inspection, seemed ok.
-Large breather hose - replaced
-Small breather hose - replaced
-Small drain hose - replaced
-Fuel Tank - removed, visual inspection. Pumped compressed air in. Seemed ok.
-Tank to pump hose - visual inspection and air pressure tested. ok. Added hose clamps
-Pump to chassis hose - visual inspection and air pressure tested. ok. Added hose clamps
Pump - visual inspection. Seemed ok.
-Chassis to fuel filter hose - haven't removed yet, seems ok on the outside. Note: has no hose clamp on chassis end.
-Fuel filter - haven't removed yet, visual inspection. Seems ok.
-Fuel filter to carby hose - haven't removed yet, visual inspection. Seems ok.
I'm now wondering what the next step is? Is there anything I can look at without going to the extreme of replacing the one in the tunnel. If I do have to replace it (or bypass it), has anyone got any advise for this?
Jiffy ·
