Joel wrote:Also the secondary turbo interferes with VW starter motors.
Precisely why they should never be used with nasty VW starter motors and gearboxes. he he
I dunno about how hard it would be to convert to single. I reckon you could remove the primary turbo and block off the exhaust flange to it, block off the primary oil and water feeds and drain. Then remove the exhaust flapper valve inside the exhaust leading to the secondary turbo and you're just about there. If you've got the later model waste gated one. There's a valve that lets boost into the intercooler from the secondary turbo which could be removed or swapped onto the intercooler input from the primary.
All the above is if you are a cheapskate.
Save yourself the trouble and get a single turbo motor. Unless you're a lunatic like me. I've got a twin turbo for my Manx. Stupid.
