Aussie Dubbin ·
Aussieveedubbers · VW Circuit Racing
IRS camber and toe adjusters... just found this
https://forums.aussieveedubbers.com/threads/90803/irs-camber-and-toe-adjusters-just-found-this
cnfabo ·
if the yanks where into there circuit stuff i think something would have been made like this for the volksy already...but nup straight line stuff it is......how bout some limiting straps...lol.....poop...
STIDUB ·
$1200USD, thats a shitload of folding stuff for something there is other alternatives for, theres alot of work involved in making it yes but i swear someone makes adjustable inner trailing arm pivots that do the same thing, granted not AS well but still... price difference wise... will try track down the inner adjusting bolts, dangerous was tinkering with something similar while i was getting some on my suspension stuff done too from memory...
quick search of germanlook & sbo says no on the bolts, just adjust the angle of the spring plate where it bolts to the trailing arm up/down for camber, forward/back for toe & you get a few degrees of movement 🙂
dangerous ·
DB's ontoit ! 🙂
Aussie Dubbin ·
Sounds good DB but how does that adjust i cant see it being off center at all. Looks like parallel sides?
cnfabo ·
me want some db.....🙂
dangerous ·
Anyone with a lathe can make a set in about 4 hours.
To get maximum camber adjustment you may have to clearance the area on the arm that is close.
Marco the steam engine on Shoptalk was doing a similar thing. I've been pestering him for ages to buy a set but nothing as yet.
Are you going to make these Dave?
I have excessive toe out on my car after fitting 944 rear trailing arms. I wanted a set of these to move my pivot point forward so that I could get the correct amount of toe.
As Dave has done, it's not necessary to replace the whole pivot box, just offset machine the stock pin and turn the adjuster sleeve to fit 👍
Aussie Dubbin wrote:Sounds good DB but how does that adjust i cant see it being off center at all. Looks like parallel sides?
Dave made the pin slightly OFFSET for adjustment
very good work
dangerous ·
Mine are slightly different to Marco's.
Marco has an inner washer that adds to the toe out, but mine does not.
Yes I can make a set,
but will need your bolts, two washers and
your urethane bushes so I can make them a firm fit inside the bushes.
$240.
$240.
Hi Dave
I will be in touch. Can you see any problem in using these to get more toe in?
Matt, Marco only fitted them to a new box pivot box for demonstration purposes.
Oh yeah, silly me, been a while since I had looked at them closely. Holzl has been looking at doing some too.1303Steve wrote:Marco only fitted them to a new box pivot box for demonstration purposes.
dangerous ·
Provided your arm clears the piviot box in the various positions,1303Steve wrote:Hi Dave
they will work for toe changes too.
Being an eccentric, to get to the maximum toe-in, or toe-out position, the camber change would be zero.
Ideally you would have the car on a machine
and watch the camber and toe numbers as you rotate the adjuster. (just like a front eccentric adjuster)
Once you have the numbers you want, then lock up the large allen bolt.
STIDUB ·
who the hell rips their rear end apart at midnight when its all bolted in nicely already? yep me! 🤪
about those 944 springplates, combined with something like those bushes, should have stacks of adjustment, oh tilting the springplate/trailing arm up/down in relation to each other makes sense now too..
When I 1st got my bug on the ground with alloy 944 arms I had really bad Toe out, I've since been able to get it almost right by elongating the holes on the spring plate and trimming a bit of the end of the spring plate.
I will look into these soon, I also have an issue with my wheel base being 30 mm too long.
STIDUB ·
wider/longer arms on the rear & alot more castor on the front added that much???
Must be all in the front caster, the rear wheels look to be in the centre of the wheel opening, fronts look to be forward.
It was one of the things that the RTA weren't happy with. Longer wheel base means that it would be classed as an ICV (individually constructed vehicle)
STIDUB ·
hi kids, while my rear end is apart (really have to find an electorplater asap!) i thought id snap a few pics of the adjustment range before getting eccentric bushes or the $$$$$$ spring plate replacement...
going off other peoples explanations of camber/toe etc these pics should help understanding whats going on...
this is original parts, no mods necessary, 8-10mm of toe adjustment..
TOE OUT
TOE IN
Pos camber - angle of the spring plate in reference to the trailing arm...
Neg camber - theres a few mm in movement, hopefully its clear enough
and the added bonus of 944 plates being height..
RAISED - outer section of spring plate in reference to the inner part
LOWERED - adjustment is done with an eccentric bolt & a locking bolt
Hope that helps people visualise what they are doing prior to attacking it 🙂
and yes its easier without torsion bars & the bushings fighting your movements but at least you can see what your aiming for now!
TOE OUT
TOE IN
STIDUB ·
oh and to save grinding the rear body/shock mount for clearance to the adjusting nuts...
try dual spring plate covers & 6mm spacer in behind the spring plate against the inner torsion bushing, theoretically it should work fine - ill confirm once ive got it all back together 👍
see the germanlook thread ive been searching for for awhile to get an idea how i mean, might have it made up tomorrow if im lucky 😉
http://www.germanlook.net/forums/showthread.php?t=10863
dangerous ·
Are you coming down this way soon Dave O?dangerous wrote:Mine are slightly different to Marco's.
$240.
STIDUB ·
possibly a sorta detour drive thru visit wednesday late arvo between the vw driving thing & the vwdcq comittee meet, attempting to source spare bolt tomorrow before driving all over the countryside with a car trailer for a friend 😵💫
JVLRacing ·
so can this work with a 69 pan.....thanks?
Sides ·
So long as it's IRS, then sure !!!
Lachlan VL ·
will db bolt bolts work on a 69 non IRS pan ?
Sides ·
Nope - swingaxles don't have those bolts at all.
JVLRacing ·
thanks sidesSides wrote:Nope - swingaxles don't have those bolts at all.
kombi_matt ·
Another very simple approach is to use some washers to space between the spring plate and the bit where it bolts to the hub. Ive seen this idea on a few slammed bay windows to correct the heinous toe out/ excessive neg camber, though it might be little different with the 3 bolt design of the beetle spring plate
JVLRacing ·
Nice work stibs..pics tell and show...
Not a nice way to rectify toe/camber on a bay, fix the problem, not the symptom.kombi_matt wrote:Another very simple approach is to use some washers to space between the spring plate and the bit where it bolts to the hub. Ive seen this idea on a few slammed bay windows to correct the heinous toe out/ excessive neg camber, though it might be little different with the 3 bolt design of the beetle spring plate
Oh, and that principle won't work on a bug, the bay suspension has a seperate bearing carrier-diagonal arm.
