Hi Everyone,
First posting, so hopefully I have done it correctly.
Can anyone tell me if the 5 speed gearbox/transaxle from a 1.9 and a 2.1 are the same?
Thanks in Advance,
Egg
Robomac 路
Aussieveedubbers 路 Tech Talk
https://forums.aussieveedubbers.com/threads/90957/t3-wasserboxer-gearbox-question
Robomac 路
ian.mezz 路
vwjon 路
Robomac 路
Thanks for the replies,vwjon wrote:in what way do you mean "the same"
answer 1 is NO, one has 4 forward gears, the other has 5!
answer 2 is yes, both take up the same amount of space and can be swapped without too much fuss
answer 3, is NO the ratios are different, but 5th = 4th on a syncro.
answer 4 is yes the gear linkage enters the same side and operates the same way.
answer 5 is yes, if both boxes are 5 speed. (not 100% sure about 1st gear ratio, but i'll do some home work)
hope that covers what you are looking for.
Menangler 路
