WTD: Rust repair cuts -1500 beetle onwards
https://forums.aussieveedubbers.com/threads/91037/wtd-rust-repair-cuts-1500-beetle-onwards
Special Air Service ·
As it says, need some repair panels for my 1300 standard beetle, parts from pretty much any 12 volt beetle will be close enough.
I'm near Taree NSW so obviously the closer to me the better, but let me know what youve got & where you are & we'll go from there. If your close enough, I may be able to come & do the cutting myself .
Before anyone starts with the "why bother", "start with something more solid" etc, the car in question holds a great deal of sentimental value so I'd like to keep it going if possible.
Here is an idea of the bits that I'm after.
front bonnet seal areas: not after the seal channel itself, just some solid metal that the seal is spot welded to.
Both rear c pillar areas down to where the engine lid is
right hand side guard mounting area
Left hand heater channel, but will probably end up buying a repro for this area.
eventually I may also be chasing a left hand rear quarter panel, mine has previously been replaced (poorly) and the alignment of the belt line, chrome trim & door opening is off a bit.
Let me know what you've got, or if you have any leads for me.
Send me a PM or reply here.
Brendan
grumble ·
Brendan give Barry a ring or come in and have a look at the bits I have,the 1/4 on the l may be salvageable.PM sent on local site.
Thanks Les
Still chasing a couple of C pillar areas (rear window to the drip rail).
I am sydney for the next couple of days if anyone has a '68 onwards beetle that they are cutting up, I will call around & have a look, I am bringing the grinder so can make the cuts myself if needed.
Brendan 0427753444
esevwbits ·
Hi i have those C cuts ready to go., call 0405 905 980 cheers Peter.
cam070 ·
Peter, If Brenden doesn't get these off you let me know I might be interested. Cheers Cam
cam070 wrote:Peter, If Brenden doesn't get these off you let me know I might be interested. Cheers Cam
All yours Cam, ddnt see the post by esevw until I got home.
Thanks to Grumble, oldtub356 & birdman I now have pretty much everything I need for my repairs.
Thanks to all.
mickya ·
Hey mate I have a complete 1500 shell, guards, lids and floor pan your welcome to take?
cam070 ·
Peter where a bouts are you located?
