Smiley wrote:OZ Towdster wrote:It will still be quite tall in first gear as a type 3 box is similar or same ratios as a 1500 swinger , what diff ratio has it got ???
Gearbox is a DC code
Diff - 4.125
1st - 3.78
2nd - 2.06
3rd - 1.26
4th - 0.89
With my tyres it should give me 2500 RPM at 100km/h.
I won't be changing to this gearbox until I get my new engine, I know this will kill the current 1600.
Now back to the topic of this thread.
So I will need two axle seals (lip seal I'm assuming?), two of the caps for the CV flanges. But not the side cover? Do they not normally leak from here? Only from the axle seal?
Smiley
馃槑
Yes,
the gearboxes don't normally leak...
only the seals -- if they have worn down
when fitting oil seals [yes. lip type] always place a few drops of oil in between the two lips to lubricate the seal,,
this should be done on all twin lipped seals , otherwise the seal will wear down until oil can get to it, resulting in very little of the lip to wear...
the 4.125 ratio differential gearboxes are OK in beetles..
Many earlier beetles have the 4.375 ratio differentials
and they go OK... good acceleration...
a bit higher revs at speed... better than having 14 inch wheels... lol
