I want to replace the wiring harness/loom in my car ..the kits available from the US are very expensive ....are they the same as the Beetle and can anyone tell me where I can get one here in Australia ...even Brisbane?
All help sincerely appreciated!❗
Leave the stock wiring to be repaired if necessary....WAY better than anything you can buy.
HappyDaze ·
Good advice, Matt. The original harness survived the 'roll' on No.8 Beetle, and I re-used it. Take care with the wires around the engine, as they tend to get harder with age [half their luck 😏] I managed to drag a '3-core flex' through the old choke cable conduit, for the tacho, oil pressure & temp. gauges.
gerggl ·
Thanks guys ... much appreciated ..so who is good at rewiring???? 🙂
gerggl wrote:Thanks guys ... much appreciated ..so who is good at rewiring???? 🙂
The same guy doing your sill replacement. 😉
bushed ·
I have a loom for a 6 vlt beetle
compl pre 60
lyin around for years
offers ?
gerggl ·
Will this work in the Safari????? .... probably a dumb question but that is why i ask questions ... knowledge is power!
gerggl wrote:Will this work in the Safari????? .... . knowledge is power!
Not really, Your 182 uses a late loom that is VERY different than an early/6V loom.
bushed ·
thanks Matt howe are you?
know anyone after a KG resto compl??
cheers for the space Gerggl
i like that name!!
gerggl ·
Too easy champion ... I guess I have a visit with an auto electrician coming up ... thanks for the kind advice!
