lots and lots of stuff. NSW still more 30-4
https://forums.aussieveedubbers.com/threads/91310/lots-and-lots-of-stuff-nsw-still-more-30-4
whatnow ·
Time to clean up and turn the multipules/excess stuff into different stuff I don’t already have...
henry
armidale nsw 2350 (new england hwy 550km north of sydney)
02 6772 8548
please pm me first.
prices not including post. i'm 2 min off the new england hwy if you know someone passing this way.
click on the pictures to view them in a better size. if you want more/better pics just ask.
If a part is not priced assume it is 1 million dollars (or best offer)
This are also advertised elsewhere, hence the request to pm me first so I know who asked first.
misc early stuff
[img]https://s3.postimage.org/ksbwqikk/early_bits.jpg[/img]
ex '58 bonnet hinges and stay $30
back seat brace bar $8
oval ash trays L>R $25 $35 $15
striker plates all show wear. top early 56 $15 SOLD. mid missmatched one like 56 one like 58 pr $10. early 58 SOLD.
door stops $10
heater sound dampers and covers ex '60. $30
heater tube $10
brake fluid resivours better $20 other $15
cover plates $25 set SOLD
4 tab VW thingies, both a bit rough, $10ea
tail lights, missing reflector retaining clips and mount screws, 1 mount bracket needs replacing. $120 SOLD
oval wipers, $40pr SOLD
oval glovebox door, rooted $5
reserve taps. complete SOLD, rough for parts/rebuild $10
oval inside handle backing spring with sheetmetal backing bit $6
blinker switch wiring covers, good $25, SOLD rough $15.
coat hooks, $15pr
fuel caps both seriously dented $12ea.
rattier than thou speaker grill and mesh $5
oval light switch. back plastic damaged. for parts/repair $5
fuse boxes. 2 fuse rough $5, 4 fuse, with cover (don't think it an og cover) $20 others $15ea.
oval wiper parts. 2 shafts and 2 linkage arms. $10 SOLD
pedals SOLD
not shown. inside mirror/visor mount bit only, rough $5
[img]https://s2.postimage.org/1w411gfdw/steering_wheels.jpg[/img]
top left mid 55? only big spline, very ratty. $45 SOLD
top right later 50's ratty $45 SOLD to the man in the middle of nowhere.
bottom left fair, $25
bottom right ex '66 type 3 nearly all of the cracks ground out for repair (several hours on the dremel) $35
[img]https://s2.postimage.org/1w51fa290/steering_wheels2.jpg[/img]
[img]https://s2.postimage.org/1w532teqs/dash_stuff.jpg[/img]
flasher can mount bar. $5
ashtrays L>R $5, $8, $8, $8
radio block off plate trims. all rough $12ea.
block off plates top 3 (58 model grey, turkis, ruby red?) $20 ea bottom two (white and beryl/mango?) $20 ea.
58-60? LHS grill and trim $30 ('60 only paprika under the brown)
speaker grill no trim 58 mod grey underneath $5
glove box doors brown (paprika) $20, orange (grey) no button $15 from memory both of these have the early opaque plugs in the back.
not shown: glove box door/trim birch? green with overspray $15. speaker grills no trim fair condition, 1 standard with no trim holes $5 ea.
[img]https://s1.postimage.org/17ko33nb8/type3_1.jpg[/img]
type 3 stuff.
glove box lids, birch green with handle and "wade racing cams, sydney" sticker $15, vw blue (my fave type 3 colour) with remains of inside sticker $10
circa 66 rear armrest, a bit rough $15
rhs mirror, no glass, nice back a few bubbles on mount $5
number plate light crome cover bit chrome ok. $10
rear reflectors, only 3 bulb mount bits/rubber covers. outside rims look good but reflectors/mount holes have some corrosion $30pr.
door locks, ex 66 matched pr, no key, look nice $20 SOLD
square popout frame (nice) $15 latches SOLD.
glovebox liner, a little sagged and a bit chewed along the top lip (i don't think it will show when fitted) $35
not shown, glove box door latch plate with screws $2
pass door handle and gaskets. very good used, no bubbles, very light scratches and a few .5mm round very shallow dings. only nasty bit is the front mount hook, see pics. $55
[img]https://s1.postimage.org/17pocoh50/type3_2.jpg[/img]
[img]https://s1.postimage.org/17puytv44/type3_3.jpg[/img]
[img]https://s1.postimage.org/17r6xexfo/trim_rings.jpg[/img]
trim rings. all rough. front two a pair, the rear two very similar. all 5. $35
[img]https://s2.postimage.org/1wf8kl3vo/trim1.jpg[/img]
late 6v pass side. decent. $40
[img]https://s2.postimage.org/1wgnu8v6s/trim2.jpg[/img]
mid 60's/ ex standard model? were red $50pr
[img]https://s2.postimage.org/1whrj571g/trim3.jpg[/img]
late 6V pass side. nice. small black mark below handle. paint? handle a little darkened $45
[img]https://s2.postimage.org/1wi4rfyzo/trim4.jpg[/img]
pass side suit turkis beetle circa 62?. no handle beading has come off, a couple of small tears in bottom back cnr. $25
[img]https://s2.postimage.org/1wiv81iw4/trim6.jpg[/img]
rear drivers side. circa 64. faded, card stuffed, missing ash tray handle. $20
[img]https://s2.postimage.org/1wj8gcauc/trim5.jpg[/img]
grey set circa 64? good. one or both the front cards are worse for wear. small tear in corner of pocket, cut/tear in one back trim, missing ash tray handle, probably some other small marks i have forgotten. EDIT: these suit a 1960 model (paprika red but prob other colours as well). $200
Two tone grey drivers door trim. No card. Two small tears in the top right corner of the door pocket opening. The pocket itself has a fair sized hole in the bottom middle. Needs a good clean.
$35
[img]https://s4.postimage.org/1dmc24678/a_little_more_001.jpg[/img]
[img]https://s4.postimage.org/1dmio9k6c/a_little_more_002.jpg[/img]
[img]https://s4.postimage.org/1dmlzc95w/a_little_more_003.jpg[/img]
56-7 rear LHS door card. No trim (gone before I got the car). Obviously some damage as seen plus a few small nicks above the trim line that don’t really show up in the picture. Card warped. $40
[img]https://s4.postimage.org/1dmz7n144/a_little_more_004.jpg[/img]
[img]https://s4.postimage.org/1dn2ipq3o/a_little_more_006.jpg[/img]
NOS stuff ALL SOLD
Sorry, no picture yet.
Splitcase gearbox
Transmission pinion shaft clutch gear 2nd gear 113 309 233A $15
Bushing 2nd/3rd gear 113 309 265 $18
2nd gear syncro feet 113 309 239A sorry only 2 $1ea
2nd Gear 113 309 261A $28
main shaft lock washer 113 309 151A $1ea
Tunnel gearbox
1st 2nd gear syncro slider 113 311 255 $30
3rd/4th gear syncro slider 113 311 315 $25
??? shaft lock/adjuster nut 113 311 237 $5ea
pinion shaft nut? $2ea
Random
Early 60’s Steering wheel blinker return catch insulating sleeve 113 951 565 $20
Split bus wiper switch. $45
KG 6V relay (horn?) 141 951 251B $35ea
Kombi front bearing cap 211 405 692 $8
Kombi washer (front suspension/steering?) 211 415 757 $0.75 ea
clutch repair kits SP402 $10ea
clutch release arms 111 141 129 $1ea (nfi why you will need them)
sway bar mount. SP94B sorry 1 kit only $10 (only enough for one side of the bar)
swing axle gater hardware kits 111 598 041 $15pr (only uber parts number freaks need apply)
golf rubber/foam? washer 171 201 119A $5
61 tail lights.
[img]https://s1.postimage.org/1ezt16qx0/more_stuff_001.jpg[/img]
All have one if not both studs broken off, all have some rust/pitting inside, the 3 complete sets include bulb holders.
Top left. Very faded OG mango paint. One lense screw snapped off in base, unbroken screw included $110 SOLD
Top right, includes rough base gaskets. The best of the sets. Early screw connectors, early no part number lenses $130 SOLD
Bottom left. Parts, what you see $30 no longer for sale
Bottom right. Right hand housing has come rust chewing around bottom edge, should be about covered by base gasket plus one hole rusted through. One screw broken short but still grabs into base threads $70 no longer for sale.
Front blinkers.
[img]https://s1.postimage.org/1f11op490/more_stuff_002.jpg[/img]
Random small bits. Most of it is self explanatory.
[img]https://s1.postimage.org/1fc497r9g/more_stuff_008.jpg[/img]
Top left, ’72 type 3 service book $25 SOLD
Late 50’s horn button parts $6
Mirrors. Lhs is a lhs mirror, no makers name, vw stamped/part numbered arm, fair condition. turns out it's an og 58-60 vert only mirror so on hold till i find out what it is worth. middle. wibroc 6V era, mirror fallen out but included. Fair overall. $30. SOLD rhs 67? wibroc Australian only style. Chrome thin and greyed, mirror loose (it is stuck in with something like bluetac that has dried with age) mirror loosing it’s silvering. $40.
50’s light up blinker arm. No lense $50 SOLD
edit, found another, pm and i'll get a pic.
dash knobs SOLD
the bottom deluxe badge SOLD
volkswagen SOLD
VW1500 SOLD
bonnet badges. Rough 3 brick $25, fair late style $30, very rough late style $15 ALL SOLD
Rossi’s
[img]https://s4.postimage.org/eztc0zvo/yet_more_stuff_012.jpg[/img]
There is a full set here plus spares, but the best rings are the middle set but they are poor, they get worse from there. Inc 6 rings, 2 light bodies, 2 bulb holders, 2 parker light holders, 4 blinker lenses, 4 blinker bases, 2 blinker bulb holders, 5 of the plastic bits that mount the light assembly into the frame and 5 ½ sets of the adjusters. $75 SOLD to the man in brisbane.
Steering column stuff.
[img]https://s4.postimage.org/f03992uc/yet_more_stuff_006.jpg[/img]
Top 60-67? Shaft, see below
Second 60-67? Shaft and tube. I think this is missing the clips and springs as seen on the top shaft, but I’m not really sure if it originally came that way. The two shafts are about 1.5cm different in length. NFI why this or what year models 60 to 67 they suit.
Third. Ex ’58 shaft and tube. Not shown but included is the clamp bit to bolt the tube to the body. The steering wheel nut it chewed as a previous owner has used a hammer and chisel to undo it… SOLD
Fourth. Tube ex 56? Oval has a different style of horn electrical contact holder to the ’58 model. SOLD
Bumpers.
[img]https://s4.postimage.org/f0eu0ias/yet_more_stuff_009.jpg[/img]
[img]https://s4.postimage.org/f0n3p8ro/yet_more_stuff_010.jpg[/img]
[img]https://s4.postimage.org/f1dkaso4/yet_more_stuff_011.jpg[/img]
[img]https://s4.postimage.org/f240wckk/yet_more_stuff.jpg[/img]
Top. Ex 56 front bar, obviously needs work, the chrome has plenty of bubbles under where the numberplate bolts on plus various other pits and scratches on the front face. The back has rust and is starting to pit. Both the over riders have some rust, one has had a good wack and the other has 2? dings. The RHS bumper iron is straight but has a fully sik custom spotlight mount bracket welded on, the LHS is bent. missing one of the plates that goes between the bracket and bar. Includes one uber rare round headed “DORN” overrider bolt (sorry in poor condition). These were an experiment by vw and were only included in one shipment of CKD kits destined for Australia. They were introduced part way through May ’56 but taken off the production line after 6-8 days due to the excessive tool wear they caused during assembly. Most were replaced during a “silent” recall at services in the first 10-20k miles. They are so rare they don’t even show up in the progressive refinements. Sorry I’m not using my NOS Matra VW tool to remove it, but I believe you can get a similar tool in an imperial size from snap on. you will need to make up a shim to get it to work on the metric Dorn bolt. $70
Bottom. Factory VW stamped stainless steel standard style front blade. Again needs straightening but it will never rust or need rechroming (plus it’s lighter than the normal one and will survive on the saltlakes). The RHS bracket is bent but the LHS is good. missing two of the bits that go between the bracket and the bar. has 3 small holes that would need to be welded when restoring. I only just picked this up and I’m not really sure if I want to sell it, make me an offer and if I like it, it’s yours.
Visor. Ex ’58. It has had a hole drilled in the centre brace to mount an ariel (not by me). Has some small dings and scrapes. Is missing one acorn nut but I think I know where it is. The mesh was once anodised blue, unfortunately it has worn off. $80 SOLD
[img]https://s4.postimage.org/f39dc0x0/yet_more_stuff_007.jpg[/img]
[img]https://s4.postimage.org/f3hn0rdw/yet_more_stuff_008.jpg[/img]
set of late 50's bosch headlights
matched non VW logo lenses A and NL stamps.
Complete, mismatched date codes. N and Q year codes from memory.
all the right bits.
all used parts with some imperfections.
$145 SOLD
[img]https://s3.postimage.org/1nwbr29vo/IMG_1715.jpg[/img]
[img]https://s3.postimage.org/1nwqmwebo/IMG_1717.jpg[/img]
[img]https://s3.postimage.org/1nx3v769w/IMG_1712.jpg[/img]
another set of early bosch headlights. these also have bosch stamped rims but i forgot to photograph them.
all the right bits bar one mount screw and 2 clips. both lenses have scratches and small stonechips. one has a chip on the edge but it should be covered up by the lense rubber. one rim has a bruise (flat spot) on it. the other is dinged, scratched and generally wonky. both reflectors are rough.
$120 SOLD
[img]https://s3.postimage.org/fyel9g5g/Picture_034.jpg[/img]
[img]https://s3.postimage.org/fyjjvhms/Picture_035.jpg[/img]
some more odds and ends. Everything is beetle, everything is 6V era unless noted.
[img]https://s4.postimage.org/2583dr9us/still_more_stuff_004.jpg[/img]
From top left.
12V seat base cover plates $5pr
seat spring $1
engine lid springs $1ea
36hp ignition wire tubes $5 ea 1 sold.
big window wiper assembly $15
big windscreen washer tank. $4
62?-67 brakefluid header tank $3
bonnet latch, drivers side pull and cover plate $7
bonnet latch, early passengers side pull and cover plate with bolts (3 by KAMAX, 1 DORN or VERBUS or something) $ 18
bonnet latch driver side pull $3
bonnet latch pull cables. 1 grey, 1 cream knob $7 ea
drivers side door handle inner brace bar. Has a bend and some pitting at the bottom. $1
rear heater outlet vent and underseat heater tube splitter $2 pr
bigwindow engine intake vent drain tube. $1
bonnet hinges and springs $5pr
LHS footwell heater outlet cover plate. $5
3 later style door stop straps. $2 all.
36hp carb brace $5
36hp ignition wire tube clamp SOLD
shift plate $1
bonnet handle, lots of corrosion bubbles $1
bonnet latch pin. painted black. A little twisted but no cracks etc. $8
inside door handle mechs $2pr
¼ window hinge plates missing 1 bolt $1pr
door sliding window rear channels $1pr
panic handle. Complete but discoloured with bubbles in chrome. $3
oval? gearhift connector cover plate cork sound damping bit. Missing 1 corner. $2
later gearshift coverplates. 1 with cork $2 1 without $1
early big seatbelt hole filler plugs/washers. Rough. I started to resurface the plugs but then found a better set. $5
gearstick set up with broken shaft. $3
front cover plates $8 set SOLD
single steering box cover plate $2 SOLD
thin shaft shifter with mad, crazy, custom, rat kulture, wild, siK, empi, okrasa, purple number 4 pool ball knob. Fit this and you’ll be fighting the pussy off with a stick. $15. please make it go away so I don’t end up using it on my buggy.
Door hinge plate $1
Porsche 356C/ 912 hub caps. Some ripples and scratch marks. Rust coming up in the ring at the back, still useable. $50pr
[img]https://s4.postimage.org/258n87fs4/still_more_stuff_006.jpg[/img]
[img]https://s1.postimage.org/spnqxbt0/still_more_stuff_008.jpg[/img]
[img]https://s1.postimage.org/sq5xu58k/still_more_stuff_009.jpg[/img]
Crowsfoot bus rims. 2 palm green, the 2 pg and the bottom right rim all dated 8/56 the other has a hoop date of 2/55 so prob mid-late 55. all missing some clips and all have some pitting in spots. $210 set. SOLD
[img]https://s1.postimage.org/sr9mqh38/still_more_stuff_014.jpg[/img]
[img]https://s1.postimage.org/srjjyk1w/still_more_stuff_015.jpg[/img]
[img]https://s1.postimage.org/ssqjxkw4/still_more_stuff_016.jpg[/img]
66-7 enginelid. Straight. Rust and some bog in the bottom, hinge section nice. Missing the body half of the hinges and the hinge pins. If I find the I’ll include them.
$70 as is $40 bare. SOLD
[img]https://s1.postimage.org/stkblts4/still_more_stuff_017.jpg[/img]
[img]https://s1.postimage.org/su0uzapw/still_more_stuff_018.jpg[/img]
[img]https://s1.postimage.org/sue3a2o4/still_more_stuff_019.jpg[/img]
[img]https://s1.postimage.org/suwa6w3o/still_more_stuff_020.jpg[/img]
early popout parts.
NOS brazilian drivers side popout frame brazilian pop outs have screws to mount the latches not rivets like the german ones. $140
black hinge covers. used $35
used hinges $30
[img]https://s3.postimage.org/ft2qx6v8/Picture_024.jpg[/img]
scripted bosch fog lights. SOLD
there is some pitting in the chrome and the odd small stone ding. not show but suit a nice og car. includes the base rubbers. sorry no brackets. i never finished cleaning the one on the right.
[img]https://s3.postimage.org/furxt150/Picture_016.jpg[/img]
[img]https://s3.postimage.org/fv3ikglg/Picture_017.jpg[/img]
[img]https://s3.postimage.org/fvdfsjk4/Picture_019.jpg[/img]
wipac battery "supercharger" $45
not working, nfi if it's a simple fix or completely rooted. the leads aren't original, a friend made them up to test it.
[img]https://s3.postimage.org/fxmh4jr8/Picture_027.jpg[/img]
fat coil 6V. $ 10 not tested. i think it is ex holden grey motor but it looks kinda like the split beetle ones.
[img]https://s3.postimage.org/fyth3klg/Picture_036.jpg[/img]
radio's 1 VA214 the other is a AWA cruiser 6. not tested. the cruiser 6 includes the speaker (dead) the mounts. Sorry aerial base not included.
[img]https://s3.postimage.org/fz8cxp1g/Picture_025.jpg[/img]
[img]https://s3.postimage.org/fzdbjqis/Picture_026.jpg[/img]
carbs.
[img]https://s4.postimage.org/1dncfxt2c/a_little_more_009.jpg[/img]
Top row. L to R
Mismatched type 3 twin carbs. On the left 32 PDSIT – 1? Ex type 3, On the right 32-34 PDSIT – 3 ex bus or mk1 golf? on twinport type 3 manifolds $100pr inc 2 linkage bits not shown.
34 PICT – 1 busted adjuster screw above the solenoid. $30
34 PICT – 1 fitted with the acc arm off a 28 PICT (to get full throttle in a 6V car) I think this has a main jet 2 sizes up from stock, choke currently adjusted fully open. $45 SOLD
Bottom row.
28 PICT fuel intake tube missing. $35
28 PICT – 1 missing it’s acc arm. $30
Nasty icepicks left pair $ 25, right pair $15. these all have LOTS of bubbles etc. the lock barrel on rh pair is chewed up.
choke cable $ 15
white/cream? handbrake button/rod/spring $2.
[img]https://s1.postimage.org/2g1mhxok/a_little_more_010.jpg[/img]
Speedo cable tubes. Top ex 60, $20 middle ex 58 $20 cable not included. bottom oval, SOLD
[img]https://s1.postimage.org/2gbjq0n8/bits_001.jpg[/img]
Things I want and am willing to swap for:
NOS/perfect used set of kangaroo door plugs. (or even singles)
Perfect og peanut blinker lense to match the one I have.
36/40hp vintage speed stuff. ken virgin/george reynolds twin carb kits/part especially.
aircleaners to suit a monaro motors twin SU kit.
turkis/turquoise ratty late 6V tail light housings.
I’m also a sucker for NOS bits so try me.
overtonsam ·
Hi do you have any early 60's slopping front guards. cheers Sam
whatnow ·
sorry i don't have any spare.
edit. i do have a pair of italian made aftermarket sloping fronts i don't need. they have no blinker holes in the top, but i drilled 3 holes in the front of each to fit some bus blinkers. similar to 56/7 us spec ovals.
i'll get some pics and work out a price if they are of interest to you.
magos ·
i'll take the rossi headlights.
can you ship them to brissie (4103)?
RISKY4LIFE ·
Hey H bag's
dang have you been stealing from the goat man again lol
some cool bits there good luck
whatnow ·
evenin' mr risk.
basically all of this is stuff i have had kicking around for 10-15 years. hence why it is for sale...
can you please pm me you number again. i keep loosing it.
whatnow ·
bump.
T-34 ·
Are the ice picks flush or recessed fitting?
whatnow ·
they are ex 56-59 beetle. i'm not sure what years of bus they would fit.
henry.
vwking ·
hi will post the charger to casino
T-34 ·
whatnow wrote:they are ex 56-59 beetle. i'm not sure what years of bus they would fit.
henry.
Mnnnn might fit my '62.
Think someone has already PM'd you about a set - I will take the set that they don't want.
Klaus ·
I'll go seconds on crows feet rims if sale falls thru
kombicafe ·
hi Henry, do u still have the:
icepick handles?
splitkombi wiper switch?
or anything that might fits to splitkombi?
whatnow ·
pm sent.
whatnow ·
40hp type 24 judson supercharger, incomplete. includes housing/rotor top pulley etc, marvel oiler and glass jar (the version they don't reproduce), belt tensioner and a homemade bottom pulley. housing re-honed and good to go but the rotor is heavily worn and needs replacing... $675 for new rotor and vanes from riccardo shipping not included or talk sweetly to your tame machinist and replace only the Al part 🙂.
$1100 SOLD $ 800
[img]https://s2.postimage.org/ygkix5k4/judson1.jpg[/img]
housing honed.
[img]https://s2.postimage.org/ygntzujo/judson2.jpg[/img]
[img]https://s2.postimage.org/ygsslw10/judson3.jpg[/img]
[img]https://s2.postimage.org/ygw3ol0k/judson4.jpg[/img]
[img]https://s2.postimage.org/yh2ptyzo/judson5.jpg[/img]
[img]https://s2.postimage.org/yh4ddbhg/judson6.jpg[/img]
[img]https://s2.postimage.org/yh9bzcys/judson7.jpg[/img]
kombicafe ·
Henry thanks for the pm mate, cant pm u just yet, i still need to post more postings to do so... give me another day alright?
cheers,
erwin
whatnow ·
they have been kicking around in boxes since the 90's, another day or 3 won't make much difference. 🙂
whatnow ·
early big window seats (pre nut frames)
pm first please as they are advertised elsewhere.
henry
0432 107 770
retrimed with no piping, vinyl still nice and soft. covers a little loose, desperately need a clean. they should clean up nicely, the patch in the pic = about 3 minutes work.
damage in the top pass side back cnr of the rear seat backrest.
i only had a quick look but couldn't see any broken springs.
located in wahroonga (near hornsby) sydney.
pick up only.
$250 if before wed midday SOLD
or
click on the pics to see the larger versions
[img]https://s1.postimage.org/2sjjrd9qc/seats1.jpg[/img]
[img]https://s1.postimage.org/2sjqdinpg/seats2.jpg[/img]
[img]https://s1.postimage.org/2sk3ltfno/seats3.jpg[/img]
[img]https://s1.postimage.org/2skbvi64k/seats4.jpg[/img]
[img]https://s1.postimage.org/2skihnk3o/seats5.jpg[/img]
edit. i have some red brown high back front seats as well. these suit earlier style runners not the L bug style
the drivers side has a 7 by 10cm ish hole on the right sholder of the backrest and the vinyl is devoloping small cracks on the seat. the pass side has a 6mm round hole on the back of the headrest but is otherwise nice.
very dusty so need a good clean.
i'll take pics if anyone is interested. offers
whatnow ·
bump.
kempos ·
Hey Henry, PM'd you recently regarding the block off plate, trim and dash cut you were trackin down. Still keen if you can give me an idea of where your at with that :-) Cheers, Lance...
whatnow ·
sorry i haven't gotten back to you. it's all good, i just have to go and cut it out.
hicks ·
Henry,
I would like to buy the early Bonnet latch, passenger side pull, with 4 bolts to attach it to body(not 3)
I live in Brisbane.
thanks Dean.
whatnow ·
no worries. i'm away till sometime next week, but will msg you then.
whatnow ·
sorry dean, i completely forgot to get back to you. pm sent.
time for some more.
early 60's doors. all of the tells for 56-59 semaphore cars bar the pull outside handles... 4 screw hinges, aluminium door(rough) and window trim, chromed steel 1/4 (one rooted the other rough). black handle braces etc.
drivers needs front corner, inner and outer.
pass needs full inner and outers. has a little rust starting under the 1/4 but it won't need welding if stopped soon. $100pr pickup only please. SOLD
[img]https://s18.postimage.org/4lp8606th/61door1.jpg[/img]
[img]https://s18.postimage.org/6ewq82hdx/61door2.jpg[/img]
[img]https://s18.postimage.org/8xif8r345/61door3.jpg[/img]
[img]https://s18.postimage.org/yuc3ld6rp/61door4.jpg[/img]
[img]https://s18.postimage.org/jmw410ex1/61door5.jpg[/img]
[img]https://s18.postimage.org/42oqah4sl/61door6.jpg[/img]
[img]https://s18.postimage.org/y8n4p9bph/61door7.jpg[/img]
[img]https://s18.postimage.org/6zbraramd/61door8.jpg[/img]
[img]https://s18.postimage.org/59y2oy5j9/61door9.jpg[/img]
bus fisheye / fried egg blinker bits.
minimal crazing, chrome paint dulled, one has silicone sealant smeared about 1/2 way around over some of the chrome bit. $30 SOLD
[img]https://s12.postimage.org/qip2shue1/fisheyes1.jpg[/img]
the worst of the crazing.
[img]https://s15.postimage.org/4bh93ab8n/fisheyes2.jpg[/img]
early fatty beetle seats. nice, one hole in one and one decent rub wearing through on the other both under the seat back. missing one adjuster know and one backrest knob. the white stuff is bird poo (no i didn't clean them) $60pr pickup only please. SOLD
[img]https://s18.postimage.org/8mam6uidh/fattyseats1.jpg[/img]
[img]https://s14.postimage.org/lslcyec0t/fattyseats2.jpg[/img]
lowlight kombi blinker bases $5pr
[img]https://s7.postimage.org/7nb6spr7r/lowlightblinkers.jpg[/img]
late bay ears, one broken tab and a couple of extra holes. $10
[img]https://s16.postimage.org/5bc5cqfsh/kombi_ears.jpg[/img]
baywindow bullbar spare tyre carriers. 1/1/2. $10 all pickup only please.
[img]https://s14.postimage.org/kc592ijq5/tirecarriers.jpg[/img]
Lachlan VL ·
have u still got the 2 front black door trims
whatnow ·
pm'd
vwking ·
hi have you still got the battery charger will you post to casino 2470
whatnow ·
pm'd
kempos ·
Still keen on the dash cut, radio blanking plate and trim if you have the time... and can post to Towradgi (Wollongong) 2518 :-)
Pumba ·
Did you get my PM.
whatnow ·
running out of room.
pick up or courier on the big stuff, i don't want to have to try and pack it.
vw blue 68 up rear guards. about 3 stone dents each. aka nice. $40pr SOLD
[img]https://s18.postimage.org/jbzz1crth/vwblueguards.jpg[/img]
split? bus rear hatch. straight, looks like there is a few spots rust in the bottom that hasn't broken through yet, i didn't have a dig at it. $80 SOLD
[img]https://s13.postimage.org/lj38z0wzn/hatch1.jpg[/img]
[img]https://s14.postimage.org/6r43bpqtp/hatch2.jpg[/img]
[img]https://s12.postimage.org/cwtx4128p/hatch3.jpg[/img]
5/76 bay drivers door. 4 ripples and 1 small ding. 1 extra hole drilled in handle area plus a little folding. a small amount of pitting in the outside of the bottom lip but it hasn't gone through. no other rust. see pics. $75 SOLD
[img]https://s14.postimage.org/6se156xt9/baydoor1.jpg[/img]
[img]https://s14.postimage.org/hghs417sd/baydoor2.jpg[/img]
[img]https://s14.postimage.org/su4bf8ib1/baydoor3.jpg[/img]
[img]https://s14.postimage.org/66p2932r1/baydoor4.jpg[/img]
[img]https://s14.postimage.org/g5a0vkc6l/baydoor5.jpg[/img]
[img]https://s14.postimage.org/6m0c23ood/baydoor6.jpg[/img]
[img]https://s14.postimage.org/i3gotk4od/baydoor7.jpg[/img]
NOS bay windscreen rubber. $35 SOLD
new polymatic late bay tail light lense. now has a small chip in the top lip as i just dropped it. $10
golf? 1600 '75 - '85 head gaskets, $12ea or 4 for $35
[img]https://s17.postimage.org/dhp99xpsr/gasket1.jpg[/img]
[img]https://s17.postimage.org/3zpi9w44b/gasket2.jpg[/img]
1 only type 3, late beetle, bay bus upright headlight mesh, some surface rust coming up on mesh. $35 SOLD
[img]https://s18.postimage.org/ckm057wyt/latemesh1.jpg[/img]
1 14" lowlight bus rim, decent. $10 SOLD
[img]https://s18.postimage.org/vojwzaz6t/busrim.jpg[/img]
[img]https://s12.postimage.org/ps9rjfeft/busrim2.jpg[/img]
'67 beetle rear clip, ok condition, nice cowl section $35ea,
[img]https://s17.postimage.org/8kgqlxu57/valance1.jpg[/img]
[img]https://s17.postimage.org/a0s942x23/valance2.jpg[/img]
[img]https://s17.postimage.org/goouqogkb/valance3.jpg[/img]
[img]https://s14.postimage.org/v7pz4sg5p/cowl1.jpg[/img]
[img]https://s14.postimage.org/84uurvpal/cowl2.jpg[/img]
used 40hp pushrods approx 75 $10 all
doesn't include the box. 😀
[img]https://s17.postimage.org/ocky0gtzv/pushrods.jpg[/img]
ok used 36hp pushrod tubes 16? off, $10 all
64-67 beetle front right guard, a couple of dents and some rust in the bottom front cnr $ 15
need some $ in a hurry so will consider reasonable offers on the judson. SOLD
Rustoration ·
Your original post has some early bosch headlights. If they are still available, the lenses look like symmetric type but would appreciate confirmation. Also, are they VW logo'ed or plain. Thanks
whatnow ·
$120 SOLD
this set is still there. they are symmetrical, no VW logo's, bosch stamped rims. click on the pics for larger versions.
Rustoration ·
Tried a pm, not sure if they are working for me yet or not. That siad, what's your best price on these posted to Adelaide.
whatnow ·
no pm on this end. i sent you a pm, hopefully that has gotten there.
if not give me a call on the number in the first post.
Pork Sword ·
Do you still have the early beetle doors? I'll be in Sydney for the Nationals weekend, any chance you are going too?
whatnow ·
hi, the doors are still here, not sure about the nationals though.
i may be able to get the doors down to my family in sydney by then though.
henry.
gotthebug65 ·
whatnow wrote:sorry dean, i completely forgot to get back to you. pm sent.
time for some more.
still got the seats ?
whatnow ·
the seats are still here if you are interested.
Weeds ·
Would love the seats, but located in Brisbane :-(
gotthebug65 ·
whatnow wrote:the seats are still here if you are interested.
ok cheers mate
